Author Topic: Speakers Crackling  (Read 8597 times)
drewmason
Re: Speakers Crackling
« Reply #10 on: 05 December 2009, 00:56 »
doesnt vary in frequency with the engine revs does it???
Offline Benji_DuB
« Reply #11 on: 06 December 2009, 11:19 »
yea it follows the loudness rather than lows. so the louder it gets the more interference and crackling there is. and there is no relation to me revving and the noise happening, its a constant crackle while the car is cold.
When the music was playing i unplugged one of the 6x9 and the noise went straight to the sub. So im guessing something is shorting near the battery? so the power supplying the amps? or something is up with my head unit, it cant be my speakers or my amps ive checked all of them.
anything sound familiar?
Offline tommk3cab
« Reply #12 on: 06 December 2009, 16:55 »
What do you mean '' the noise went straight to the sub''?
you mean it was coming though your 6x9's but when you unplugged one then the sub started doing it?
what do you have running from what? HU running 6x9's and front speakers then amp running sub?
EDIT: you have the right idea unplugging things though, try to eliminate/isolate the cause.
« Last Edit: 06 December 2009, 16:56 by tommk3cab »
Offline Benji_DuB
« Reply #13 on: 07 December 2009, 17:22 »
The sound was coming through the 6x9's so I unplugged both of them and the crackling 'bitty' sound went to the sub.
My 6x9's run off an amp and so does my sub, so ive got power cables from the battery individually powering each amp.
Thanks for the reply! im going to keep unplugging things and see if i can eliminate it!
When i eventually get the time and this is still happening, do you recon it would be useful for me to replace all the cables? I just have a feeling that somethings shorting but i havnt got a clue where, so im guessing the best thing to do is to just take it all out and start again? Just to see if the problems eliminated?
Offline tommk3cab
« Reply #14 on: 07 December 2009, 18:46 »
and the sub was not making any unusual noises?
do you have your sub low passed? they shouldn't ever make crackling noises really, the filter should stop it.
It sounds like its something to do with the HU to me.
Try unplugging the RCA's from the HU end but still connected to the amp..
if it still does it then its not the HU
if it doesn't then it is.
try unplugging the RCA's from the amp end but still connected to the HU...
if it still does it then its not the HU or the RCA's
turn off your HU before unplugging and reconnecting the RCA's though.
It seems strange that the noise went when you unplugged the 6x9's. Are you sure the noise was not just quieter through the sub, so when you disconnected the 6x9s it became more obvious that the sub was doing it too?
Offline Benji_DuB
« Reply #15 on: 08 December 2009, 23:50 »
no its defo the 6x9's that were the original source of the crackling, as soon as i unplugged them while music was playing, the sub continued but crackling appeared lightly in the sub sound.
yea im starting to think its the HU aswell, ive had the same set up for years and no problems, so theres only a few things it really could be.
Thanks alot for the replys, il try everything youve suggested and see what happens. im just hoping its nothing stupid lol
Offline babyvw
« Reply #16 on: 09 December 2009, 08:14 »
ave u got ur phono leads running down the same side as ur power cable to ya boot!? they can pick up on the current and then ya amp picks up on it and plays it through ya speakers my old corsa did this till a run pwoer lead down one side of car and phono's the other specailly if u got to of everything!?
my mk3 8v for sale 700 or offers
Offline tommk3cab
« Reply #17 on: 09 December 2009, 14:46 »
I would love to see that proved. It would be a first on a worldwide level, you could be a pioneer, maybe even in the guiness world records book.
Offline babyvw
« Reply #18 on: 09 December 2009, 17:14 »
well my old corsa used to do i had the big gauge wiring run up side with phono's and asked my local audio shop at the time what to do to stop he told me that i tried it and it worked!!
Offline tommk3cab
« Reply #19 on: 09 December 2009, 17:59 »
Poor local audio shop  :rolleyes:. Believing the dame myths as everyone else.
The noise stopped due to the movement of the RCA's
