Author Topic: Updated oil breather hoses  (Read 11770 times)
Offline navmk4gti
Re: Updated oil breather hoses
« Reply #30 on: 30 October 2009, 20:50 »
 :shocked: the awesome ones are fookin expensive.. and yes the £15 ebay ones are good quality.. very thick and strong and i cant fault them one bit .. and especially for the price  :grin:
had a snoop around for ya Tim found and finally found the guy does em on ebay.. its volksbits :wink: AUM silicone breather pipe   :smiley:
Offline T_J_G
« Reply #31 on: 30 October 2009, 20:58 »
Yeah been out of stock for ages Nav.
They're getting some more made up by a different company as I messaged them earlier today!
Offline navmk4gti
« Reply #32 on: 30 October 2009, 21:02 »
is he  :sad:
how long did he say hes gonna be wid em?? im sure they will be good quality mate.. brought few bits and bobs and never had problem  :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #33 on: 30 October 2009, 21:03 »
The top hose takes 5 minutes to replace, so even if the cheap one has to be replaced every couple of years it's not the end of the world.
Buy 3 for less money than the awesome one and Roberts your mothers brother!
did you time me doing that aswell then? :grin:
Offline T_J_G
« Reply #34 on: 30 October 2009, 21:06 »
is he  :sad:
A weeek till he has a delivery date. My hole isn't getting any smaller either :(
Offline golf-sib
  • Турботазик
« Reply #35 on: 30 October 2009, 21:09 »
Talked to a seller on eBay before I did some of my silicone and here is what he said:
Quote
"All the normal silicone is actually resistant to oil vapors/mist, so it will work in the breather system, if a build up occurs of oil, like in a breather system such as it becomes a solid/liquid deposit. Then that will slowly wear away, only cure is to change silicon or buy thicker stuff to begin with as it will still happen, the difference maybe visible sooner or later but it will happen, so buying thicker stuff to begin with is always a better choice. Another choice is an oil catch can that’s meant to aid and reduce oil deposits in the system
Only time I would advise other silicone is if you are working with fuel or the oil pumping/cooling side, then you need special silicone which becomes pricey as it is specifically designed to withstand long term and extreme conditions"
I am more than happy to believe him, as I’ve seen how easy it was to cut the silicon in the car where the deposits were and weren't. But for that price from AwesomeGTI, I would turn away, I have spent £160 changing all my breather piping, vacuum and TIP for that price, most expensive silicone was for the breather and I made a mount and installed an oil catch can. Heres a break down:
£90 TIP
£30 Breather piping "coupling silicone" (0.75m) + Joints
£40 Vacuum piping (3m of one size and 2m of another) with Jubilees
I bought a oil catch can for another £15 which I made a mount and colour coded the mount with the car, I will upload some pictures later of how it turned out, my only advice is if you do install an oil catch can, for it to be effective the piping must be flat level or descending  when it head to the breather, ascending the piping or not keeping it level will reduce the oil catch cans effect, as the oily vapors have to travel upwards, whilst an oil catch can, catches oil via gravity, so you kind of eliminate or reduce the effect of it by having ascending piping.
It’s like fiber glassing the dots on the engine cover, then smoothing it, why not use paper-Mache, why not use that instead its fire and water proof, plus far cheaper.
Hope this helps, just my two pence
EDIT: here my engine with the breather silicon, before I added the oil catch can, TIP and replaces vacuum piping, I'll take a more recent one soon:
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline navmk4gti
« Reply #36 on: 30 October 2009, 21:10 »
sounds like hes gonna be a few weeks then  :sad:
you wont damage nothing will ya with a hole in it?
Offline T_J_G
« Reply #37 on: 30 October 2009, 21:11 »
Don't think so but it won't run right.
Offline navmk4gti
« Reply #38 on: 30 October 2009, 21:13 »
golf-sib what have you put on your engine cover looks like fabris???  :huh:
get one from VW then mate...incase you end up damaging something else in the process waiting for one  :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #39 on: 30 October 2009, 21:25 »
tidy.. paint your throttle body black :cool:
