Author Topic: 5x100 wheel spacers???  (Read 1883 times)
Offline chrissywood
« on: 28 October 2009, 18:55 »
i got a mk3 gti on bbs rx2s 16" its lowered about 40mm but i want the wheels spaced out a bit more how much can i go??? how much should i go??
where can i get some cheap wheel spacers from???
Re: 5x100 wheel spacers???
« Reply #1 on: 28 October 2009, 18:59 »
10mm really and don't use cheap spacers, venom or ebay is your best bet.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 28 October 2009, 19:10 »
I will say max 12mm...but trim the plastic arches a little on the inside (if you run them) as 205 tryes will touch slightly!! (or fit 195's)
nick_thomas
« Reply #3 on: 28 October 2009, 21:23 »
My 195s rubbed slightly with 15mm spacers. Nothing horrendous but not what you want.
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 28 October 2009, 21:34 »
I have a box load of 10mm hubcentric spacers. 57.1mm centre bore and they're 5x100 / 5x112 multifit for mk3/mk4/mk5. You'll need to get yourself some longer wheel bolts though (ebay!)
forum offer £40 a pair plus delivery! .. or you can spend 100 quid+ on h&r :lipsrsealed: :laugh:
Offline GTI-Steve
« Reply #5 on: 28 October 2009, 21:55 »
Don't buy cheap spacers
And i would only recommend hubcentric ones, you can get wheel wobble, uneven tyre wear etc from ones that don't sit on the hub - the weight of the car is only supported on the bolts otherwise
There is chap on Ebay - ESP engineering, based in Crowborough, who makes excellent quality ones...
As far a show big a spacer you can fir depends on the ET of your wheels
mine are ET31 and i run 15mm spacers each at the rear and the arches don't catch as they're rolled and pulled slightly
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 28 October 2009, 21:56 »
That's who makes mine. Chap's name is Liam. I can do them a bit cheaper to forum members than he does on ebay as i got a box load.. like i said :grin:
Offline JackJack
« Reply #7 on: 28 October 2009, 22:03 »
Depending on my MOT I might have to take you up on that offer  :grin:
