Author Topic: Replacement gearbox for 16v 9a - can I use an 8v box?  (Read 2502 times)
Offline Skiing
Well, bombing up the A1 on Saturday morning and changed into 4th gear. And then stayed in 4th gear. And then could not get out of 4th gear despite fiddling with linkage and the best attempts of the AA man.
So box is most likely busticated.
So, need to have it replaced and can't afford re-con box at this stage - have a budget of £500 from AA insurance thing (including labour) - so thought a second hand box would be the best route (although of course risk of it going phut too).
However, 16v boxes like hens teeth - so can I use an 8v with my 9a bottom end? - I know its possible with standard bottom end (except the clutch is different) - but is it possible with the 9a?
Any help would be great. H
1988 Golf GTi Mk2 16v 2.0 9a bottom end- Oak Green - 3 door - full black factory leather...
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
Re: Replacement gearbox for 16v 9a - can I use an 8v box?
« Reply #1 on: 28 October 2009, 15:41 »
I think the clutch is different size, as a mate of mine is after an 8v Mk3 box but bought a 9A by mistake. He has it for sale if you're interested mate. Pm me if you are.  :wink:
Offline monzablue16v
« Reply #2 on: 28 October 2009, 15:46 »
I had an 8v box on my mk2 16v. It went like stink as well :) 8v clutch and 16v flywheel worked on mine :)
Offline Skiing
« Reply #3 on: 28 October 2009, 15:49 »
Cheers so far - I know an 8v box in a 16v can be quite a good combo... especially for 5th gear slightly less frantic cruising on the motorway - but not sure whether 9a bottom end wont work with an 8v box or not? hopefully t'will bolt up easily? - Dan7 re. the 9a box your mate got - think this is a cable change box and I want to stick to rod change for the moment - but thanks anyway.
« Reply #4 on: 28 October 2009, 15:51 »
double check tghe gearbox code, to confirm which one it is.  the MK2 8v box is very close in terms of ratios to the 16v box anyway. early one is same 1-4 except 5th is taller so lower revs on motorway, later 8v box is same as early 8v except 2nd is taller as well.
boxes are physically the same shape, just as said above the 16v box has a bigger input shaft, so if you do have a 16v box now you need an 8v friction disc.  As above, double check the gearbox code so you know whats up :)
Offline Skiing
« Reply #5 on: 28 October 2009, 16:10 »
Legend - thanks RJ - have passed onto the garage which is sorting the car out.
Offline leeroy20vt
  • h reg mk2 gti
« Reply #6 on: 28 October 2009, 16:49 »
a 8v box will deffo fit this is what im running in my mk2
only thing i found that at 60 mph on motorway the engine is doin 3000rpm which i thought was quite high tbh
Offline Mew
« Reply #7 on: 28 October 2009, 17:25 »
9a is the code of the early mk2 8v box, as well as the 2.0 16v bottom end :smiley:
Offline Tubb
« Reply #8 on: 28 October 2009, 18:52 »
if its an early 8v box then you may need to change the driveshaft flanges to the 16v 100mm versions. this also means 'modifying' the gearbox casing
I had to do this to get a mk1 box to fit
1987 Golf GTI 16v 2.0 - 1993 Autocavan Demo Car - For Sale!
1992 Pulsar GTi-R
Offline Skiing
« Reply #9 on: 29 October 2009, 10:32 »
Right gearbox people have said that 3rd and 4th are knackered and reverse is pitted.
They have quoted me a full rebuild of everything include stainless bolts for the diff for £525 incl. vat - good price? will come with guarantee etc.
