Author Topic: Replacement gearbox for 16v 9a - can I use an 8v box?  (Read 2504 times)
Offline raferackstraw
Re: Replacement gearbox for 16v 9a - can I use an 8v box?
« Reply #10 on: 29 October 2009, 13:43 »
have you tried tes engines in darenth? they will recondition your existing box and fit it
give them a call 01322 350022
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
« Reply #11 on: 29 October 2009, 14:56 »
if its an early 8v box then you may need to change the driveshaft flanges to the 16v 100mm versions. this also means 'modifying' the gearbox casing
I had to do this to get a mk1 box to fit
All MK2 1.8 gearboxes have the 100mm flanges on, even the drivers. MK1 1.8 may have 90mm flanges though :)
Offline Tubb
« Reply #12 on: 29 October 2009, 19:02 »
ahh, i wasnt sure if it was early mk1s or early mk2s with the 90mm ones
1987 Golf GTI 16v 2.0 - 1993 Autocavan Demo Car - For Sale!
1992 Pulsar GTi-R
Offline paultownsend
« Reply #13 on: 30 October 2009, 10:07 »
i have a abf 16v in my mk2 with my old 8v aug 020 box. the ratio's are perfect and cruising on the motorway is a delight. in 4th it'll pull to 100 very easily. 5th off the clock. easily
