Author Topic: Please Help  (Read 3114 times)
Offline golf96
Please Help
« on: 26 September 2004, 21:15 »
I have a Golf Gti 8 v 96 & i am having this jerking when I am accelerating. Once i get to about 40+ this goes away. I have changed the plugs, dis cap rota arm, leads air filter, & have checked for air leaks on manifold & air pipes too. I have even tried putting in super unleaded & this hasn?t changed it at all Please any one got any help???????????
Offline customboy
  • I LOVE MY TURBO!!!
Re: Please Help
« Reply #1 on: 26 September 2004, 22:54 »
have u tried to see if none of the pipes are blocked or hoses might be loose?
maybe the air intake might be blocked try making sure that no electric sensors or plugs are loose also make sure ecu wiring hasnt got loose and not conected proberly
hope this helps a bit mate i ahd the same problem on my fiesta once was just the ecu was a bit loose
good luck
Offline richellis
Re: Please Help
« Reply #2 on: 27 September 2004, 16:53 »
try cleanin the throttle body. if its coverd in sh!t that wont help.
MK3 Golf GTI
Offline golf96
Re: Please Help
« Reply #3 on: 27 September 2004, 21:20 »
Thanks for the replies, I have cleaned the throttle body that?s all spotless, Also have checked the air intake, but must admit haven?t tried the ecu wiring, can some one please tell me where I will find this? Thanks again for replies
redcarboy
Re: Please Help
« Reply #4 on: 27 September 2004, 21:47 »
Check to post 2 down from yours could be the coil? :)
Offline golf96
Re: Please Help
« Reply #5 on: 27 September 2004, 22:37 »
Hi please explain this bit - Check to post 2 down from yours?  I understand could be the coil is there a way of checking this be4 going out & buying one?
Thanks for your reply
Offline RobGTI
Re: Please Help
« Reply #6 on: 30 September 2004, 17:22 »
Check this thread out. I'm in the middle of trying to sort a similar problem (although mine is inmtermittent).
http://www.golfgtiforum.co.uk/index.php?topic=12494.0
Edition 30, Black, 3 dr, Manual, Xenons, Highline, Sunroof, Armrest, Cruise, Touchscreen Nav & Bluetooth.
Offline golf96
Re: Please Help
« Reply #7 on: 04 October 2004, 20:06 »
Have 2 day had a mate fit a new coil for me & fingers x it seams so much better so much smoother, I have ordered the relays to change as well so that I know that they have been done to so will post again in a couple of weeks to update ya on how its going.
Offline golf96
Re: Please Help
« Reply #8 on: 22 October 2004, 17:37 »
 Well  >:( after a couple of weeks its back to jerking on acceleration again, mainly in 3rd & 4the between 20 - 45mph. I have now been out and brought the genuine VW lead set & king lead & cap & rotor as the other were from German French & Swedish & was told that this could be your problem but no its still doing it & I am now ?87 down for the coil & ?125  for the genuine leads & stuff. Please help me I am going mad as apart from this the car is fine but I am loosing my patience with it now & it?s driving me mad. Have also changed the ECU & FUEL RELAYS so it?s not then either  ??? ??? ??? ??? ???
mrwotto
Re: Please Help
« Reply #9 on: 22 October 2004, 21:01 »
have u had your timing checked mate?
Your timing may be out!
