Author Topic: How do you remove these bushes?  (Read 1045 times)
Offline Mikester
  • Civic Type R
« on: 19 October 2009, 21:00 »
How do you remove the 2 bushes either end of the front subframe?
They are wrapped around a metal tube, with a metal ring on either end.
I need to remove them as i want to get the subframe powder coated, then replace with powerflex bushes.
I sprayed it with hammerite, but its just not good enough i dont think.
Re: How do you remove these bushes?
« Reply #1 on: 19 October 2009, 21:12 »
Only a guess but if they are like the Audi ones then cut down through them with a hacksaw or burn them out.
VW BUSH
« Reply #2 on: 19 October 2009, 21:33 »
Drill
Offline bored_Welsh_lad
« Reply #3 on: 20 October 2009, 07:33 »
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline AudiA8Quattro
« Reply #4 on: 20 October 2009, 08:26 »
I think the standard bushes are pressed in?
