Author Topic: Quick question - fuel pump at fault?  (Read 2156 times)
Offline jmsheahan
« on: 18 October 2009, 17:34 »
Having a couple of issues with my 8v digi today - was driving along and noticed an odd whirr coming from the rear end of the car at idle in traffic. Noise got louder and louder until the car cut out. Car starts and drives fine but noise comes and goes when stationary at different audible levels.
Is this likely to be the fuel pump? If so I've read there are 2 - how do I test which one is at fault? I've had a gander through the search engine but if anyone could shed anymore light on the subject I'd appreciate it.
Offline Steve_B
Re: Quick question - fuel pump at fault?
« Reply #1 on: 18 October 2009, 18:50 »
Must be the fuel pump. Had this noise myself a couple of times today so will be following this thread interestedly. I'm sure this has been covered before though, will have a quick look.
edit: just found this, think it's what we need to check
http://www.golfgtiforum.co.uk/index.php?topic=77136.0
« Last Edit: 18 October 2009, 19:03 by Steve_B »
Offline Ben Lessani
« Reply #2 on: 18 October 2009, 22:16 »
If the whining got louder - I would have thought the lift pump was failing to supply fuel and starved the main pump.
When was the last time you changed your fuel filter?
Offline jmsheahan
« Reply #3 on: 19 October 2009, 14:23 »
Cheers for replies - new in tank pump ordered. No idea on the filter, should probably change that too.
Offline Ben Lessani
« Reply #4 on: 19 October 2009, 17:57 »
Wait - you've ordered it without testing? I'm all for internet diagnosis, but make sure you actually test it before replacement!
Offline weazgti
« Reply #5 on: 19 October 2009, 19:47 »
Read on somewhere that vw use a lifetime filter.
Is this true?
Offline 16vLeroy
  • Grr bloody car, if everything was as reliable as a
« Reply #6 on: 19 October 2009, 21:54 »
Fuel pump whining, then cutting out? Time for a new injection pump. The one under the car, next to the filter.
Oh, and it's the most expensive one too....  :sad:
For the sake of a few pounds, i'd change the filter.
Offline jmsheahan
« Reply #7 on: 20 October 2009, 00:52 »
Yeah I've tested it following the advice from the link above. Not fully convinced but for the sake of 20 odd quid from the local GSF it's cheaper to change this first than the main pump. And yeah new fuel filter to go on too.
Thanks for all advice, much appreciated. Will report back soon with any findings.
Offline 16valve
« Reply #8 on: 22 October 2009, 10:28 »
Make sure you also buy the hose that connects to the main pump as usually rusted solid and snaps upon removal..
