Author Topic: Clutch peddle bitting point  (Read 1629 times)
Offline johnson6672
« on: 18 October 2009, 09:41 »
Is there any adjustment for the height at which the clutch peddle bites, mines right at the top, i have tried adjusting the cable although only quickly.
There doesn't seem to be any slip, but i have only taken it for a blast down the road and back.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
VeeDubGTI16v
Re: Clutch peddle bitting point
« Reply #1 on: 18 October 2009, 10:16 »
auto or manual adjust cable?
if auto its stetched and needs replacing, if manual take up the slack on the thread or replace if you cant!
id go for the manual adjusting clutch cable if it needs changing
if that doesnt work your clutch is worn out
« Last Edit: 18 October 2009, 10:20 by veedubgti16v »
Offline Ben Lessani
« Reply #2 on: 18 October 2009, 22:17 »
Mines *right* at the top, with the cable adjusted as loose as possible - my clutch is definitely on its way to a better place :(
Offline johnson6672
« Reply #3 on: 20 October 2009, 19:33 »
Bugger, i was thinking about this after i posted and i think i may have adjusted the wrong way and taken the slack up so will have to have another play with it when its not raining. It's a manual adjust cable by the way, i think i was just being a mong the other day
Offline johnson6672
« Reply #4 on: 31 October 2009, 15:38 »
I was being a mong, adjusted it again today and all is good, no slip and biteing point feels good, doh!
« Reply #5 on: 01 November 2009, 00:15 »
 :cool:
Offline mar_k
« Reply #6 on: 03 November 2009, 11:26 »
my biting point is quite high aswell,
i suspect the clutch is worn.
what kind of adjuster is there on a 2000 golf gti 2.0?
will give it ago before i dive in
Offline Sam
  • Sam I am
« Reply #7 on: 03 November 2009, 11:49 »
Try the correct section for your car mate
Offline mar_k
« Reply #8 on: 03 November 2009, 13:03 »
sorry
