Author Topic: Mods for my new gti  (Read 2711 times)
Offline astburygti
Re: Mods for my new gti
« Reply #10 on: 17 October 2009, 16:26 »
Here are a couple of pictures as it stands now, its the 2 litre 8v model
« Last Edit: 17 October 2009, 16:41 by astburygti »
Offline Mikester
  • Civic Type R
« Reply #11 on: 17 October 2009, 16:27 »
As for wheel size, it will drive and handle bette ron 16's but if you want to compromise handling for looks, go for 17's.
Cheers, not fussed on looks more for performance with in reason, and 16" are alittle cheaper :smiley: What sort of ride heigth is best for fast road use??
On 16s maybe a 60/40 set up, maybe a little higher.
Offline shogun
  • its a golf day
« Reply #12 on: 17 October 2009, 17:17 »
side skirts topps??? :cry:
Offline astburygti
« Reply #13 on: 17 October 2009, 17:33 »
The drivers side one was missing, got one odered from dealers :wink:
Offline Mikester
  • Civic Type R
« Reply #14 on: 17 October 2009, 17:37 »
Make sure that the end bit is fixed on before you take it away, as one of the end caps is glued on, and cant be refitted, but breaks off VERY easy.
I had to get a 2nd one as the dealer broke my first one.
Then i de-arched and de-skirted my car the month after! haha
« Reply #15 on: 17 October 2009, 19:22 »
16"s are better for clearance and handling, I ran 17"s and a 70mm drop did have a few issues with clearance on the back but sorted it with an a angle grinder.
Offline Dan GTI
« Reply #16 on: 17 October 2009, 21:13 »
Well you are missing at least 8 valves and have 2 doors too many - but other than that  :grin: :tongue: I'd go down the route of slamming it as a number one priority - it will stop it handling like a boat! Don't go too low would be my advice! I've gone low, and having covered 250 miles since the coilovers have "settled" and now I'm even lower - and as a result I ended up with 2 incidents today - incident 1 - speed bumps one Golf nil and new spliter now required - bugger as its a failry new VR6 one I put on the car about 3 months ago. Incident 2 - MOTSTOP couldn't get it on the ramps at the test centre for the MOT test :embarassed:
Don't bother with the trubo would be my advice. If your going to spend all that money sorting out compression, rod ends, turbo's etc etc I would just drop in a 20v turbo and box from a mk4 gti. You'll have to fiddle around with some bits, but it would probably cost alot less and give much more power with better power curves.
16's are plenty. 17's on low profile tyres and coilovers WILL ruin your spine! If you've got cash to burn splash on some BBS split rims :smiley:
I'd look at tarting up the body and a S/S exhaust system - but nothing too boomy.
Speed Bumps 1 - 0 Golf GTI
Offline astburygti
« Reply #17 on: 18 October 2009, 17:03 »
Thanks for all of your comment chaps, keep them coming :smiley:
