Author Topic: alternator belt on abf  (Read 7196 times)
Offline richard s
« on: 17 October 2009, 11:58 »
my abf engine used to run air con and i have removed the air con pump so i ordered a new grooved belt for it and after going through 3 belts i finally got the one for the alternator with tensioner
i fitted new belt and its not right as it catches the back of the waterpump pulley
is there a different alternator bracket for non aircon engines or do i have something missing
cheers
Offline Diamond Hell
  • Opinions я Us
Re: alternator belt on abf
« Reply #1 on: 17 October 2009, 13:12 »
It's a completely different set up, sorry - you'll need the alternative alternator mount, but I seem to recall the bracketry off a 2E without a/c will fit up, so that should make your scrapyard browsing less painful.
Offline danny_p
« Reply #2 on: 17 October 2009, 18:43 »
you need non aircon mk3 ltr bits normaly 8 valve.    waterpump pully,  alternator and alternator mounting bracket
all the VW's have gone bar 1.
Offline richard s
« Reply #3 on: 18 October 2009, 16:44 »
cheers guys
while searching scrappers if i come across something like a mk3 1.8 will this have the same parts i need or is it just the 2.0 engine i can get the parts from
« Last Edit: 18 October 2009, 22:08 by richard s »
« Reply #4 on: 19 October 2009, 09:28 »
no you dont, all you need is non A/C waterpump pulley from any 1.8-2.0 8v or 16v MK3, and the correct non-A/C belt.  You just need to figure out which of the tensioner setups you have, the seperate tensioner type bracket had 2 revisions with different belt lengths.  This goes by year:
92-95 = 976mm
96-97 = 1038mm
Offline richard s
« Reply #5 on: 19 October 2009, 12:43 »
cheers that should make finding one a bit easier
  • Opinions я Us
« Reply #6 on: 20 October 2009, 11:54 »
Sorry, I should have clarified - you need the above if you want to run a ribbed belt, which will work better.
 :rolleyes:
« Reply #7 on: 20 October 2009, 14:33 »
erm no, you still run a ribbed belt with the above.
the only difference between an ABF with and without A/C is the waterpump pulley and the length of the belt. oh and the fact there is an A/C compressor or not.
  • Opinions я Us
« Reply #8 on: 20 October 2009, 20:43 »
I must be dreaming the two different illustrations of the alternator bracketry in ETKA then, much like the two different bracketry set ups that I have about 300 meters from here and the two different ways of tensioning the belt that are used a/c vs non a/c, but then what do I know?
Offline danny_p
« Reply #9 on: 20 October 2009, 21:55 »
the brackets for the aircon setups i have safely filed in the bin do defantly look much diffrent from the non aircon setup on the car
