Author Topic: Gamma Head Unit in a MKII? also any other head units?  (Read 2120 times)
Offline nathyd
Hi there,
 I've had to replace the original tape head unit I had, now i've bought a universal apaptor and have been using a mates cd player
but it skips all over the place and i want to go back to a tape cassette so i can use my i-pod through the tape cassette.
will the gamma one's i've seen on ebay work with my MKII?  also I borrowed a rover 770 tape head unit and that was locked so do I hvae to worry about security codes with the head units I buy?
thanks alot in advance, I am very much a newbie
Offline dragonfly
Re: Gamma Head Unit in a MKII? also any other head units?
« Reply #1 on: 15 October 2009, 20:40 »
Standard fit headunits tend to be a little weedy. If you want to use your ipod then either get a cheap tape player off ebay, buy an FM transmitter or buy a cheap headunit that will control your ipod as well.
Offline nathyd
« Reply #2 on: 15 October 2009, 21:34 »
thanks, so any tape head unit will work on my mk2?
Offline nathyd
« Reply #3 on: 15 October 2009, 21:35 »
also will the gamma from mk4 retrofit to a mk2?
Offline dragonfly
« Reply #4 on: 15 October 2009, 21:51 »
Just check that the existing Golf headunit wiring hasn't been hacked. Once you know what the wiring and connections are like you can compare them to the replacement headunit.
