Author Topic: CAR STATIONRY THE REVS ARE GOING UP AND DOWN AND THE ENGINE DOES TOO????  (Read 5302 times)
Offline nottsforest
it goes down 2 to 3 mim and up 2 to 3 mm so not much but i wanted an r tech remap but untill its runnin right i aint riskin it please contact back thank you
Offline topher
  • Administrator
  • fully functioning
engine revs measured in mm.. brilliant :grin:
doesn't sound like it's jumping wildly, most likely throttle body needs cleaning then
Offline nottsforest
mm movement of needle i aint a car repairer lol and some times when you go to accelerate its does responed you have to lift ya foot and re apply does this sound like throttle body???? were is throttle body and how much for a new one??? is it a quick job???/ cost etc???
Offline topher
  • Administrator
  • fully functioning
if its faulty, new one from a dealer is about 200 quid. A used one off ebay might cost you £80 or less. Cleaning it takes about 30 minutes if it's carbd up bad. Wire wool works well... need to adapt it after cleaning though (search!)
Offline nottsforest
where do i locate the throttle body pal i aint into cars fixin that is would i be able to do it by myself
Offline Rhyso
If you use THIS you will find the answers to your questions HERE
Offline northeast_gti-t
  • "1.8T AGU"
remove four hex head bolts the jubilee clip securing the hose and the small hose at the top of the t/b
2000 Mkiv GTi 1.8T AGU
Offline dai-cymru
  • 1989 MK2 16V
If your not confident in repairing a car take it to a local garage recommended locally to you
Offline nottsforest
me dads been fixin cars 40 years he can do it, i love the golf forum if id have seen this before i would have been here its really usefull and thanks to you all,
Offline nottsforest
so topher do you think my throttle body has gone and need a new onee with what i explained?? revs up and down a few rpm and throttle dont respond sometimes when pressure is applied dont always do tho cus if so it wouldnt move good lad
