Author Topic: CAR STATIONRY THE REVS ARE GOING UP AND DOWN AND THE ENGINE DOES TOO????  (Read 5268 times)
Offline nottsforest
hi do i need to do the throttle body enlignment on a 51 plate????? or do i just take it off clean it and set the thing to 0 and then start and run car???
Offline nottsforest
so its it a special tool to reinlign the thing
Offline nottsforest
thought you could clean it yasen set the moter back to o and thats it???
Offline snap-on
clean the throttle body , refit etc and make sure car has no fault codes stored before you do a adaption and as you have a 51 you will have drive by wire so reset body . does your dad have a scanner/code reader ?
Offline nottsforest
right i get it clean throttle body set moter to 0 then go to vagcom to get it set up properly??? yeah im i right
Offline snap-on
what you mean set motor to 0 ? and you can use any scanner doesnt need to be a vagcom .
Offline nottsforest
no he just takes em to garage to get read still dont under stand tho call me thick i wanna get it right pal if you could explain the full details in  order of what i got to do id be gratefull very, i dont under stand why its got to go to be read after cleanin it?
Offline nottsforest
topher says motor needs settin to 0 postion once its been cleaned
Offline snap-on
right this is how i done mine -
1 , check for fault codes first with scan tool as you might find another or different problem/fault . mine has code p1297 turbo/throttle housing pressure loss so i cleared code .
2, remove and clean throttle body as shown in pics in the previous posts and refit it
3, use a snap-on , vag com , reflex etc etc scan tool . i use snap-on , plug in set up and go to functional tests in menu and go to adaption . click yes and the throttle adaption will start which the scanner will open and close the throttle butterfly approx 8 times and reset all its values .
4, start car , job done
Offline snap-on
if your dad goes to a garage i would imagine they use snap on as most do , colour graphing , solus , modis etc all do the same
