Author Topic: boost gauge fitting  (Read 4627 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: boost gauge fitting
« Reply #10 on: 09 October 2009, 21:48 »
2000 Mkiv GTi 1.8T AGU
Offline navmk4gti
« Reply #11 on: 09 October 2009, 23:11 »
northeast is that where you have to run it off (my gauge is coming monday  :smiley:).. as i though you run it off the vacum pipe that goes on the dv??  :undecided:
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #12 on: 10 October 2009, 15:12 »
either pipe works there both connected to the inlet i would rather tap the dv though as i wouldnt want my fuel unexpectedly to cut off when driving one day if something you piped wasnt a good long lasting fix if you get what im saying
Offline navmk4gti
« Reply #13 on: 11 October 2009, 00:59 »
exactly what i was thinking mate as dont seem keen on fookin around with fuel pipes  :wink:
should get my gauge on monday  :cool:
Offline barry-gti
« Reply #14 on: 11 October 2009, 11:56 »
Just do it properly and then there wont be no problems. how is one easy cut and a T-Piece going to cut off fuel? cable tie the pipe to the T-Piece if you're worried.
Offline jase16gti
« Reply #15 on: 11 October 2009, 12:32 »
why not get the vacum from here
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 11 October 2009, 17:08 »
Your not mucking abut with fuel lines, that's the vac line that goes to the FPR. All these pipes are linked so it wouln't make any difference if it split there or near the DV, the resulting leak would be the same.
Jase have you tapped into the inlet for that? I don't have a vac line take off there...
Offline navmk4gti
« Reply #17 on: 11 October 2009, 17:18 »
i dont have a vac line from their either  :huh:
mine is a AGU engine code prob thats why
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 11 October 2009, 18:33 »
T into the vac lines at some point then
Mine is in the same place as Matt's, then I've run the pipe under the injector rail for neatness  :wink:
Offline T_J_G
« Reply #19 on: 11 October 2009, 18:50 »
same!
