The garage
mk2 gti gearbox's
Topic: mk2 gti gearbox's (Read 2723 times)
Blue MK2
Guest
mk2 gti gearbox's
22 September 2004, 22:30 »
I want to fit a 16v gti box on my 8v gti. wat else would i need to replace? Clutch plate was it
mechanical junkies help me out here
Gambit
Forum addict
Re: mk2 gti gearbox's
23 September 2004, 09:20 »
input shafts are bigger so u need a 16v clutch
tbh there is no gain in puttin a 16v box into an 8v
davidhawkins_78
Valver Bad Boy
23 September 2004, 10:35 »
Would make for interesting driving though - I'd imagine a 16v box is geared for the engine revvin' between say 4 and 7 grand; really a 8v should be driven from 3500 to 5500.
You change gear frequently enough in and 8v without having a 1500 rpm power band that a 16v box would give you !! (well in theory)
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Gambit
Forum addict
23 September 2004, 10:49 »
if you get the gearbox code of your current box and compare it against the 2y box using this link you'll find there is no real difference
http://www.scirocco.org/gears/
its a pointless exercise. u should only be lookin to change your box if its mangled!!
Gambit
Forum addict
23 September 2004, 10:53 »
the different 2nd gear ratio in the 16v is to allow it to hit 60mph, because in those days it was all about 0-60 times!!
and 8v with the same gearing will not hit 60mph in 2nd as its unable to rev high enough
davidhawkins_78
Valver Bad Boy
23 September 2004, 10:54 »
Rub it in why don't you ....
Blue MK2
Guest
Reply #6 on:
23 September 2004, 11:54 »
the reason why im askin is coz ive got a nasty crunch and can get hold of a puka 16v one
Gambit
Forum addict
Reply #7 on:
23 September 2004, 11:58 »
then fire ahead with it!
david - u know u'd love a 16v
davidhawkins_78
Valver Bad Boy
Reply #8 on:
23 September 2004, 12:02 »
Looking back I should have got one, but given the money and time I had I'm still over the moon with what I got !!
If I wasn't planning an engine conversion I'd be on the hunt I must admit
I'm quite tempted just to get a 2.0 16v from a mk3 - ALOT cheaper than say a g60 - and 180 bhp should be easy from that ...
Gambit
Forum addict
Reply #9 on:
23 September 2004, 12:13 »
and a lot more reliable.
G60's are gettin long in the tooth nowadays - id stay away from any thoughts of doing a conversion with one
The garage
mk2 gti gearbox's
