Author Topic: dash swapping  (Read 3017 times)
Offline 1300mk2
dash swapping
« on: 22 September 2004, 19:43 »
remember hearing a while back about  a mk5 polo dash going into a mk2 golf. anybody else heard of this? also what are the first considerations when undertaking a dash swap. i take it its essential to own the haynes manual for the doner dash for the wiring diagrams?
Offline Dizzie
  • Make friends with your fast
Re: dash swapping
« Reply #1 on: 22 September 2004, 21:17 »
u can download most of the wiring diagrams off the net if you need them. when I did the mk3 swap all the wires were same colours so I didn't have much head scratching to do :)
just rip out the mk2 dash and throw in the polo one. you'll soon see where needs cutting to make it fit. you'll probably need to weld in a support bar you should get from the polo. the whole dash screws to that. welding is the best option as long as you get it in the right place first time  ;)
you might need to make up some air ducts with fibreglass. best option is to get the matrix from the polo as linking the mk3's controls (knobs) to the mk2's matrix was impossible as the mk2 was sliders. The mk3's matrix bolted in relatively painlessly and works perfect now. might need to drill new holes in the firewall though. Don't cut the bulkhead out if things won't line up else the car will fall apart! Make up new peices from fibreglass to work round the problems.
and most importantly - take lots of pics!
hit me back if you want some help or advice on something :)
Offline 1300mk2
Re: dash swapping
« Reply #2 on: 23 September 2004, 20:20 »
help much appreciated dude. work may well commence this weekend, providing the cam belt change goes smoothly.!!!
