Author Topic: 1.8 SE MOT emissions failure  (Read 2626 times)
Offline devolute
  • Mk3 1.8 SE '96
« on: 07 October 2009, 17:46 »
I'm failing on emissions.
On a fast idle test I get 0.611% (max 0.300) and a lambda of 1.034 (max 1.030)
This was a re-test. After failing with similar numbers the first time, I was given some liquid to put through the engine. I did this, ran the car round a bit, then bought some of this:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_274571_langId_-1_categoryId_165750
..with another tank of fuel.  No joy.
The guy at the garage didn't have any suggestions so I turn to you, forum. I have absolutely no idea what the next course of action is.
My Golf has only (!) 85k on it, so I don't want to retire it just yet. The car is in good nick, otherwise.
Offline Mikester
  • Civic Type R
Re: 1.8 SE MOT emissions failure
« Reply #1 on: 07 October 2009, 17:47 »
Are you running any mods on it?
Offline devolute
  • Mk3 1.8 SE '96
« Reply #2 on: 07 October 2009, 17:53 »
Nope. Aside from some rather tacky wheels that the previous owner put on it, it's completely standard to the best of my knowledge.
Offline Mikester
  • Civic Type R
« Reply #3 on: 07 October 2009, 18:10 »
Well i would think that its either the cat that is broken, or that its overfueling, which has ruined the cat.
Could be over fueling due to a broken/mis reading sensor.
But im not sure how those engines work tbh.
Offline devolute
  • Mk3 1.8 SE '96
« Reply #4 on: 07 October 2009, 20:37 »
Thanks anyway Mikester.
I may take it to my local 'VW specialist' before I break down and take it to my local VW dealership.
« Reply #5 on: 07 October 2009, 20:39 »
+1 sounds like a cat or mixture problem
Offline AudiA8Quattro
« Reply #6 on: 07 October 2009, 21:26 »
Try changing the lambda probe before the cat.
Offline Mikester
  • Civic Type R
« Reply #7 on: 07 October 2009, 23:14 »
And check the wiring i reckon.
Offline Khare
  • The bear that khares
« Reply #8 on: 07 October 2009, 23:17 »
I'd find someone with vagcom and do a scan, might not be the lambda probe at all. Lambda probes ain't cheap so I'd start off with the cheapest stuff first, like a throttle body clean, and air filter renewal.
Offline Mikester
  • Civic Type R
« Reply #9 on: 07 October 2009, 23:23 »
Needs a difinitve answer, as mot retests are expensive. Thats the problem.
And does a non gti have fault scanning compatability?
