Author Topic: 1.8 SE MOT emissions failure  (Read 2629 times)
Offline Khare
  • The bear that khares
Re: 1.8 SE MOT emissions failure
« Reply #10 on: 07 October 2009, 23:25 »
Thing is it could be the lambda probe, but then again it might not be. So if you replace it then that's the most expensive fix wasted. I could be as cheap and simple as air filter renewal or throttle body clean.
Offline devolute
  • Mk3 1.8 SE '96
« Reply #11 on: 08 October 2009, 10:54 »
It recently had a full service, so all the air filters should have been replaced.
« Reply #12 on: 08 October 2009, 11:05 »
I would still check.
Offline boneybradley
  • Back in a Mk3...
« Reply #13 on: 08 October 2009, 20:16 »
try the lamda as the reading looks too high (a new bosch universal one is under £50) and also get a temp sensor (£6 well spent)..
oh and all mk3's are vag-com ready (obd1 if pre 95 and obd2 with "full reading" from mid 95... all e.u sold cars had obd2 from 1995 when euro2 emissions came in to force  :wink:)
gtigolfthree
« Reply #14 on: 08 October 2009, 20:30 »
Or mabye the engine is fcucked how many miles has it done and does it use (burn) oil?
Offline devolute
  • Mk3 1.8 SE '96
« Reply #15 on: 08 October 2009, 22:27 »
It's done about 85k miles. The engine doesn't seem to go through a noticeable amount of oil and for what it's worth, it sounds 'normal' (My pal had a 1.8 Driver - same engine, same sound).
Offline AudiA8Quattro
« Reply #16 on: 09 October 2009, 00:22 »
Replacing the probe is the cheaper fix, otherwise it will be a new cat.
Offline Guy
« Reply #17 on: 09 October 2009, 07:57 »
At the risk of sounding immensely stupid here.. I once had a calibra (cue flaming) and that failed on emmissions. Turned out to be the O2 sensor..
a) is that the sensor everyone is on about
b) does a mk3 even have one of these, I would guess it does in some guise
3) If it does then is it worth considering as it was a very quick and cheap fix
  • Back in a Mk3...
« Reply #18 on: 09 October 2009, 20:15 »
yep same sensor....and it's bolted to the front pipe before the cat
