Author Topic: Bad times, Drive Shaft bolts  (Read 3490 times)
Offline Mikester
  • Civic Type R
« on: 07 October 2009, 16:43 »
Not really sure how this happened, but i rounded 3 of 6 Drive shaft bolts on the VR today.
I soaked them in WD and left for a while, 3 came out fine, the other 3 just spun and rounded.
I used a torx bit on a small breaker bar.
Going to try and use mulgrips on them tomo to remove them, if not...... Well.......
Any ideas?
 :grin:
Offline AudiA8Quattro
Re: Bad times, Drive Shaft bolts
« Reply #1 on: 07 October 2009, 16:52 »
They are not torx heads, they are splined.
Try using irwin extractors.
Offline Mikester
  • Civic Type R
« Reply #2 on: 07 October 2009, 16:57 »
Crap. lol.
Cheers :)
« Reply #3 on: 07 October 2009, 16:59 »
Also when you undo these bolts, always clean out the middle and bang the socket in, then you shouldn't be able to round them.
Offline Mikester
  • Civic Type R
« Reply #4 on: 07 October 2009, 17:05 »
Im going to pick up a hex set from machine mart tomo, and i will bang them in for sure.
Going to give the rounded ones a go with the propper hex bit, as i only tried twice on each then left them so i can still have a pop at them.
http://www.machinemart.co.uk/shop/product/details/cht144-40-pce-torxspline-bit-holder-s/path/screwdrivers-bits-hex-key-sets-2
That will do the job wont it?
Offline Mikester
  • Civic Type R
« Reply #6 on: 07 October 2009, 21:27 »
Yep. Cheers for that. I will get one of those to remove the 3 f**ked ones.
And some splines to remove the other sides drive shaft :)
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #7 on: 07 October 2009, 23:37 »
TBH knocking on a slightly bigger spline tool will do the trick, then make sure to use the spline tool when fitting the new ones.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline Mikester
  • Civic Type R
« Reply #8 on: 07 October 2009, 23:39 »
I will use the bolts that on my mk3 8v at the moment probably to put into the VR box, as i am using my 8v driveshafts on the VR box, as i think its all the same :)
But i might just buy the splines, and give it a go. And if it fails get the extractors. As i have lots of other bits to buy, so if i can get away with not buying something. i will.
Offline Matty-MK3
« Reply #9 on: 07 October 2009, 23:40 »
Don't be cutting corners though mate, it will only cost more time and money in the end.
