Author Topic: Bleeding brakes, can i do just one?  (Read 2132 times)
Offline wobblybob
« on: 02 October 2009, 15:35 »
Hi, ive had the rear passenger side caliper of my 88 jetta gti as ive hjad the nipple replaced as it snapped, am i able to bleed just that one caliper or will i have to do them all? i did a search and found the sequence but i dont want to start snapping nipples on the other calipers? any tips? thanks
Offline james_16v
  • 1986 Golf GTI 16v
Re: Bleeding brakes, can i do just one?
« Reply #1 on: 02 October 2009, 15:47 »
I changed my drivers side rear caliper last month and got away with just bleeding that corner.
Hope this helps
« Reply #2 on: 02 October 2009, 16:06 »
Better to do all 4 as you could leave air trapped in the system.
Offline wobblybob
« Reply #3 on: 02 October 2009, 17:05 »
i read i need to clamp of the brake bias? i had a look at it and how does it mean clamp it off?
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #4 on: 02 October 2009, 18:17 »
clamp it together to let the fluid through
Offline wobblybob
« Reply #5 on: 02 October 2009, 18:51 »
so it thinks theres lots of weight in the rear? gotta ya, cheers for the help, i'll give it a go tomoz
Offline orbit48
  • OAK GREEN VALVER is no more.....
« Reply #6 on: 02 October 2009, 20:04 »
hello mate,    you can usually get away with just bleeding the corner you are working on,  but it is much better pratice do all the lot while you are messing about with the brakes anyway.
if you do only bleed one corner, take the car for a quick blast after and if the brake pedal feels spongy then you are probably best off bleeding all the brakes
hope this helps matey
Offline wobblybob
« Reply #7 on: 02 October 2009, 22:15 »
Hi, thanks i'll try it tomoz, i know my way around a car but didnt want to start bleeding the rest and snapping more nipples, will update tomoz, hopefully with pics to help anybody else, thanks Kevin
Offline AudiA8Quattro
« Reply #8 on: 04 October 2009, 13:01 »
Make sure you seal the reservoir before removing the caliper, a plastic bag and an elastic band will work.
Then you will not lose much fluid, so will only have to bleed that corner.
If the system has been changed for a while then do the lot.
Offline Ben Lessani
« Reply #9 on: 06 October 2009, 12:50 »
Surely now would be the time to remove all the nipples and replace them then? If you leave it longer, it might be even worse, but you *might* stand a chance at the moment.
Do the job once and right ;)
