Author Topic: Maybe stupid idea? maybe not.  (Read 3512 times)
Offline Khare
  • The bear that khares
« on: 02 October 2009, 13:45 »
Right, I have been thinking about it in the past, and it probably is a stupid idea and you will laugh, BUT, in theory, it SHOULD work.
/Flameproof suit on
I have an old vacuum cleaner motor along with it's switch and the cable. I have tested it and it works perfectly. Now my theory is, if you mount it on the air box, using a power converter (which I have, 12v-240v) to power it, and then run the switch in the cabin to turn it on/off, do you think it would make any difference? In theory it should, as it is filling the air box VERY quickly with nice air. Like an electric supercharger style.
Views please.
Offline MowatGTI
Re: Maybe stupid idea? maybe not.
« Reply #1 on: 02 October 2009, 13:48 »
Doubt it.
It might cause a build up of air pressure.  Engine might not run rich enough.
Give it a go though.
Offline jv
  • Administrator
« Reply #2 on: 02 October 2009, 13:52 »
will only work if you put helium in your tyres at the same time.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline christomk3gti
« Reply #3 on: 02 October 2009, 13:55 »
 :laugh:  :laugh:  :laugh:
If you try it, make sure you upload some pics. and show the test results.
 :smiley:
Black 8v GTI............. Whats a Waffle Valve?
Offline harlemex
« Reply #4 on: 02 October 2009, 13:56 »
Try it. I think you could be on to somethin here  :cool:
Offline Jay
  • balding fat cvnt
« Reply #5 on: 02 October 2009, 13:57 »
noooo he doesn't want Helium he wants Tungsten Hexafluoride  :evil: Just don't let your tyres get too cold otherwise you'll have a sloshing in your tyres  :laugh:
« Reply #6 on: 02 October 2009, 13:58 »
If you run the vacuum from an intake in the bumper somewhere then you will get nice cold air. but not if its just sat on your air box sucking up your engine heat.
Offline shepgti
« Reply #7 on: 02 October 2009, 14:00 »
try it, will be a laugh :wink:
« Reply #8 on: 02 October 2009, 14:01 »
but what ever your decide. it has got to be a MUST do mod.
We'll all be dismanteling our hoovers shortly  :grin:  :grin:
Offline Khare
« Reply #9 on: 02 October 2009, 14:03 »
wait a minute....helium is lighter than air.....lightweight wheels reduce unsprung weight....see where I'm going with this?  :grin:
Obviously I'd have a good cold air intake running to it, both for cold air and to keep the motor cool.
I'm gonna get hold of an used air box and try some ideas and do some planning, I'm interested in what the results could be  :smiley:
Quick question. The power converter has a +ve and a -ve wire, can I run them straight to the battery terminals without fusing it? or should I fuse it?
