Author Topic: Boost Leak - CONFIRMED RED TURBO PIPE GONE - NOW FIXED  (Read 9110 times)
Offline Rhyso
« on: 30 September 2009, 18:51 »
coming home tonight put my foot down at approx 70mph in 6th
no black smoke as usual but instead a hissing sound much like a boost leak
the hissing sound starts at 2500rpm and ends at approx 2800rpm - car 'feels' like its slightly down on power
No fault codes  though I have had a plume or two or white smoke - however sat at idle and revving the engine produces NO smoke but the noise is apparent
Got it booked in tomorrow morning but should I fear the worst  :undecided:  Oil and coolant levels seem ok
 :cry: :cry: :cry: :cry: :cry:
« Last Edit: 02 October 2009, 10:50 by Rhyso »
Offline Adam
Re: Strange Problem
« Reply #1 on: 30 September 2009, 18:58 »
 :cry: Oh nooo
Does this mean I'm going to beat you on the RR?  :lipsrsealed:
Down Hill From Here.
Offline Rhyso
Re: Strange Problem
« Reply #2 on: 30 September 2009, 19:00 »
:cry: Oh nooo am I going to beat you on the RR?
unless its a cheap and easy fix I won't be going at all  :cry: :cry:
Offline wayne_gtiT
Re: Strange Problem
« Reply #3 on: 30 September 2009, 19:03 »
maybe its boost leak and beens as your turbo trying to compensate it buring it out, if you get what i mean
what RR?? is rtech doing another? sorry to hi jack
Offline richw911
Re: Strange Problem
« Reply #4 on: 30 September 2009, 19:03 »
Offline Rhyso
Re: Strange Problem
« Reply #5 on: 30 September 2009, 19:06 »
Loose intercooler pipe?
http://uk-mkivs.net/forums/p/238516/1538283.aspx#1538283
checked all the pipes and they seem secure  :undecided:
its the lack of black smoke that worries me as every time i've had a boost leak it runs like sh!t and chucks miles of of it out the back
Offline Adam
Re: Strange Problem
« Reply #6 on: 30 September 2009, 19:07 »
Nooooo! Fix it.
http://www.golfgtiforum.co.uk/index.php?topic=121304.0
Offline richw911
Re: Strange Problem
« Reply #7 on: 30 September 2009, 19:10 »
Hmm true bud  :sad:
one of the posts says
"i had the problem of the noise, not the smoke or lag though, was a split in the pipe from the intercooler, took the front drivers side wheel off, and the inner plastic surround and its all easy to get to then, just a matter of undoing some nuts and its all free! "
 :undecided:
Offline Rhyso
Re: Strange Problem
« Reply #8 on: 30 September 2009, 19:12 »
Hmm true bud  :sad:
 :undecided:
couldn't see anything obvious - dammnit - where's Mr Dave and his boost leak tester when I need him lol
Offline Adam
Re: Strange Problem
« Reply #9 on: 30 September 2009, 20:11 »
And if you had a boost gauge  :rolleyes:
