Author Topic: Boost Leak - CONFIRMED RED TURBO PIPE GONE - NOW FIXED  (Read 9084 times)
Offline Rhyso
Re: Strange Problem
« Reply #10 on: 30 September 2009, 20:26 »
And if you had a boost gauge  :rolleyes:
hmm thats a thought - wonder if the bung for the take-off in the EGR has come loose / off  :undecided:
Offline DarkGti
Re: Strange Problem
« Reply #11 on: 30 September 2009, 20:58 »
turbo problem? :lipsrsealed:
Offline Rhyso
Re: Strange Problem
« Reply #12 on: 30 September 2009, 21:01 »
thats worse case scenario so less of that talk please
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Strange Problem
« Reply #13 on: 30 September 2009, 21:16 »
Time for hybrid then,  Can we get in carried out before saturday?.. :smug:
The worst case is a is a crack in the turbo which is opening up under load and extream heat bleeding the boost off and leaking oil into the hotside.
How many times did it do it? and is it still doing it?  If it keeps doing it you need to try and get a sniff of the white smoke to find out if its oil. water or fuel bore wash.
Nick
 01455 617233
Offline Rhyso
Re: Strange Problem
« Reply #14 on: 30 September 2009, 21:22 »
Won't be going hybrid as i would need an uprated intercooler then
had a look and there wasn't any oil splattered over the turbo and when revving when stationary there's NO smoke at all  :undecided:
the noise appears without fail at 2500rpm and goes by 3000rpm
Had a look at all the pipes but couldn't see anything obvious - will check again in the morning for leaks.  I'm hoping its something simple such as a perished o-ring around the intercooler pipework
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Strange Problem
« Reply #15 on: 30 September 2009, 21:24 »
so do I mate  :sad:
Offline RTechUK
Re: Strange Problem
« Reply #16 on: 30 September 2009, 21:28 »
 01455 617233
Offline Steve_PD
Re: Strange Problem
« Reply #17 on: 30 September 2009, 21:30 »
Hopefully it is something simple
Thats what my car does, noise disappears after 3k and pulls harder :undecided:
Offline Rhyso
Re: Strange Problem
« Reply #18 on: 30 September 2009, 21:32 »
is it a full on hissing noise like a boost leak would make?  :undecided:
Offline Steve_PD
Re: Strange Problem
« Reply #19 on: 30 September 2009, 21:34 »
mines like air rushing through the system, then it clears and pulls harder
