Author Topic: Ported throttle body  (Read 2265 times)
VW BUSH
« on: 28 September 2009, 20:45 »
Some pics of mine, did the back today :wink:
Font for good measure
Nearly forgot to top up coolant afterwards :rolleyes:
Offline Khare
  • The bear that khares
Re: Ported throttle body
« Reply #1 on: 28 September 2009, 20:50 »
I did mine on Friday night at DH's place. Yours looks good, good job. Haven't driven it yet, but it had been started up. Idles like a bit of a pig and sticks at about 1300 revs a little bit when maneuvering. at full throttle though should be a right old laugh  :cool:
« Last Edit: 28 September 2009, 20:54 by Khare »
VW BUSH
« Reply #2 on: 28 September 2009, 20:59 »
did you do the back?  its quite bumpy there got loads off.
Carbide burr's slice ali like butter took seconds done quite a few of these now, does help to be The Engineering manager  :grin:
Offline Khare
« Reply #3 on: 28 September 2009, 21:08 »
Yeah back too. I used a hand file haha, took a while and gotta admit, idle is probably like it is due to the fact I got a bit too keen on some parts. If I had used a dremel then I would have had no probs at all.
VW BUSH
« Reply #4 on: 28 September 2009, 21:10 »
oohhh scrapey :grin:
VW BUSH
« Reply #5 on: 28 September 2009, 22:46 »
Gives you an idea how much came out of the back :smiley:
Offline Khare
« Reply #6 on: 28 September 2009, 22:55 »
Can't really see too well on those pics, but looks about the same as mine. Just like the inside of a bog roll, smooth with no humps  :smiley:
Offline axewielder
  • 95 dragon 8v
« Reply #7 on: 29 September 2009, 09:19 »
prob took too much off around butterfly if idling wierd, mine idles just as before i smoothed mine but throttle response is much better esp. from low revs.
Offline Khare
« Reply #8 on: 29 September 2009, 09:29 »
Yeah that is the problem. It's because I used a hand file rather than a dremel.
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
« Reply #9 on: 29 September 2009, 09:32 »
is there a sticky for how to do this?
- just found one!
« Last Edit: 29 September 2009, 09:40 by hyland770 »
