Author Topic: body work gti  (Read 2082 times)
Offline steveo
body work gti
« on: 23 September 2009, 21:56 »
hi all, have just started doing the body work on my gti, and have decided to remove all the body trim on the car as any one done this? have been told u filler in the gaps wear the trim was, (a lot of filler needed then nor not???) thanks for any info sent back, steveo.
« Last Edit: 21 October 2009, 12:57 by steveo »
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
Re: workshop manuak
« Reply #1 on: 23 September 2009, 21:59 »
 :huh: ever heard of haynes manuals? there available everywhere.....
Offline AudiA8Quattro
Re: workshop manuak
« Reply #2 on: 23 September 2009, 23:00 »
Offline steveo
Re: workshop manuak
« Reply #3 on: 24 September 2009, 13:11 »
had a look at them, trying to get hold one for a gti is like pulling teeth   :undecided:
Offline Andy-H
Re: workshop manuak
« Reply #4 on: 24 September 2009, 13:18 »
It's included in the manual for the lower models  :wink:
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline steveo
body work,
« Reply #5 on: 21 October 2009, 12:47 »
hi all, have started doing the body on my gti, and have decided to remove all the trim on the body as any one done this?? the arch trim is,nt a problem but once you remove the body trim your left with that gap, i,ve been told you filler it,(blimey a lot of filler then??) thanks for any info steveo.  :huh:
Offline Len
Re: workshop manuak
« Reply #6 on: 21 October 2009, 12:55 »
You need GL or some VR6 door strips mate! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Mikester
  • Civic Type R
Re: body work gti
« Reply #7 on: 21 October 2009, 13:20 »
Late VR trims.
But yes you can remove the arches, then fit the non arch side trims, and also remove the side skirts.
Using filler to smooth the door trims would be terrible, needs to be welded etc.
Re: body work gti
« Reply #8 on: 21 October 2009, 15:40 »
Late VR trims.
+1 you will the doors welded over, filler will fall out.
Offline Matty-MK3
  • Automatic boats FTW.
Re: body work gti
« Reply #9 on: 21 October 2009, 19:08 »
As above. Filler will crack and fall out. Filling with primer (has been done before) will likely crack. Fiber glass will crack.
Or so me mate tells me! :grin:
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
