Author Topic: Stage2 R-tech Boost Levels  (Read 2034 times)
Offline Grand Master Patch
« on: 23 September 2009, 21:29 »
Anyone on here running a stage2 map and a boost gauge? What psi are you getting?
Offline DarkGti
Re: Stage2 R-tech Boost Levels
« Reply #1 on: 23 September 2009, 21:33 »
stage 2 do you mean agu ko3s? if so mine boosts just over 1.5 bar
« Reply #2 on: 23 September 2009, 21:37 »
Yes,i guess it would be the same for an AUM. 21psi sounds good to me :cool:
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 23 September 2009, 21:42 »
it should hang at 20-21psi briefly then settle to 16-18 until pretty much red-line
remember the agu head flows marginally better so pressure may be lower but volume is the same.
airflow=everything
Offline DarkGti
« Reply #4 on: 23 September 2009, 21:47 »
what n-valve you running? when i had mine remapped by r-tech it i was running the n75-j and was boosting at 27psi which nick said that was over boosting and reccomened me to put the original valve back on but the f-h should be fine for 22- 25! :wink:
« Reply #5 on: 23 September 2009, 21:50 »
I'm on the original,had a look at weekend and it's the C version.Ohhhh all this boost,bring it on :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 23 September 2009, 21:50 »
Mine holds at about 17psi after the run this evening, didn't see what it peaked at as I was looking out for the old bill who seemed to be everywhere lol
I also ran out of road as the 200m of dual carriageway was a bit busy, guess I'm gonna have to wait for the RR day
I run a standard C valve
« Reply #7 on: 23 September 2009, 22:01 »
airflow=everything
Very true,basically boost is just back pressure that is in the system that isnt used by the engine.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 23 September 2009, 22:04 »
How long you got to wait until you get yours done mate?
« Reply #9 on: 23 September 2009, 22:19 »
It's getting mapped on friday
