Author Topic: ive got stuck!!!  (Read 3093 times)
Offline jo
  • im not as think as you confused i am
ive got stuck!!!
« on: 18 September 2004, 12:13 »
im not literally stuck...tho i am in a sticky situation
have done as advised on checkin my relays..well i tell a lie..i havnt..because i cant get to the bloody things >:(..okies..so help me out here..
have removed the panel where the fuses are kept..can see the relays..but how do i get at them??
have unscrewed the screw that is visable on the bottom left..but it wont come away because there is more screws behind the panel below the steering wheel...u gettin all this?? :-\
hmmph...dont wanna force ne thing..as i live alone and have no-one to help me out if i break it...what do i do nxt??..haynes manual isnt revealin ne thing..sumone tell me wot to do nxt..im desperate..need to check my relay number 30..and do they just pull out?
apologies if i made no sense at all ;)
97 mk3 gti
"praise the lowered"
Offline jte
Re: ive got stuck!!!
« Reply #1 on: 20 September 2004, 12:36 »
To get the large panel around the fuse box cover off, you need to reveal the screws at the top by removing the sort of long thin bulgy cover just below the steering column, i think this is the one in your description.
This thing is in two parts and both just clip off.  Try inserting a long flat head screwdriver behind them and carefully prising them away.  They are not that hard to get out so you shouldn't need too much force.  Try pulling at different angles if they won't come off.  There are two or three screws for the main panel behing these two covers.
I think overall there are 5 or 6 screws but the rest are not hidden.
Once you remove the big panel the relays will be obvious.
As for removing the relays i think you just pull them straight out.
Good luck
(by the way, if the worst happens and you do break a cover, it doesn't matter, it has no effect on driving the car, it's only a cosmetic cover)
A VR6 isn't a way of life, it's just a car.
Offline Len
« Reply #2 on: 20 September 2004, 13:04 »
Dont really need to remove anything else other than the fuse box cover. I did then found i didnt need too.
I know its hard to see each relay but if ya look at the Haynes manual it shows ya where the relays are and you can just count from one side and pull out the right one.
Yes they just pull out, shouldnt be a problem for a lady that makes cakes, u shld have long strong fingers, probably find it easier than i did. Just give them a little wiggle side to side, not much, and they should pull out easy. If not get some long nosed pliers but dont grip too hard.
www.sas.org.uk
www.the-ace.org.uk
Speedydub
« Reply #3 on: 20 September 2004, 13:46 »
<hijack>
Cakes???  :P :D
</hijack>
I find haynes manuals a bit complicated  :-\ I bought a different one for a fiver, can't remember what it's called- will try remember to bring it to Newark so you can see what I mean  :-*
Offline Len
« Reply #4 on: 20 September 2004, 13:57 »
A cake for a look at a manual - fair swop!
Just had a look at mine again, very difficult to see, unless ya get down on hands and knees outside the car, (with door open of course!) U can just see em. But i think by touch is better - always!
www.sas.org.uk
www.the-ace.org.uk
Speedydub
« Reply #5 on: 20 September 2004, 14:08 »
I looked in mine when I was changing the rear lights.....no info at all on how to do it  :-\
Whereas the other manual had color pix and everything  :D
Offline jte
« Reply #6 on: 20 September 2004, 15:51 »
Haynes Manuals are cack.  According to one i had removing a front seat was of the same difficulty the replacing the head gasket.  Granted it was a renault and i did have to remove the exhaust centre section and heat shield to remove a seat.
Also the mk3 golf haynes manual doesn't cover the vr6 engine :'(
I wonder if haynes do cake manuals. :D
Offline Len
« Reply #7 on: 20 September 2004, 15:59 »
Granted i agree - haynes manuals are crap. Undo this and remove! Utter Boll*cks!
But in this case it gives a diagram of the relay board and its easy to read and work out which relay is which.
www.sas.org.uk
www.the-ace.org.uk
Offline jo
« Reply #8 on: 21 September 2004, 22:41 »
 ;D..manual for cakes
got at me relays..eventually..and it looks like the buggers are ok... ::)
soooo...to be honest the car hasnt cut out in a few days...kinda thinkin..would it have cut out if relays were loose??..some of em were..till i gave em a nudge in ;)
so now hopefully all i have to do is put me wheels bk on..and im ready steady go for Newark..woohoo
 :D
97 mk3 gti
redcarboy
« Reply #9 on: 21 September 2004, 22:51 »
I would think its possible relays could have just been loose bit of dirt bad connection just have to wait and see hopefully you got it sorted now. ;D
