Author Topic: COOLANT LEVEL LOW  (Read 11255 times)
Offline Aidy06
COOLANT LEVEL LOW
« on: 20 September 2009, 16:57 »
Just got a message on my car saying coolant level low, the needle is still in the middle though. When i got home i checked the coolant and it's below the min line, ive only had my car for 4months from new so it shouldn't have ran out that fast should it?
Offline simonpolly
Re: COOLANT LEVEL LOW
« Reply #1 on: 20 September 2009, 17:03 »
Maybe it was low when you picked it up,also we are coming to the end of the summer ,i`ve had mine 2 months and my coolant is half way between min and max,i`ve done close to 1500 miles
Golfgti build quality is average at best.
Offline Aidy06
« Reply #2 on: 20 September 2009, 17:10 »
Whats the best coolant to top it up with?
Offline simonpolly
« Reply #3 on: 20 September 2009, 17:16 »
It tells you on it i think its g20 or something like that,just look on header,its pink and vw sell it,can`t remember off the top of my head,               ITS G12 BUY IT FROM VW NOT VERY EXPENSIVE AND YOU WON`T USE MUCH.
Offline Rhyso
« Reply #4 on: 20 September 2009, 17:26 »
yep its now called G12++ and is about £5 for a litre or so from your local stealer
keep an eye on the level though as you may have a very small leak
top it up to between min and max and keep an eye on it - the system will find its own level but if it drops dramatically over a couple of days then get it checked out ASAP
oh and the needle in the middle is for your coolant temperature  :wink:  any higher than 90 stop driving immediately!!
« Last Edit: 20 September 2009, 17:29 by Rhyso »
Offline Aidy06
« Reply #5 on: 20 September 2009, 17:32 »
Seems strange though how it's so low, surely it cant have a leak at 4months old? I turned engine off and back on and the warning light went out, it hasn't come back on since. I need drive 30miles to work tomorrow aswell  :shocked:
Stealers dont open till 9am but there is one right by my work, just hope i can make it there in 1 piece  :laugh:
Offline Rhyso
« Reply #6 on: 20 September 2009, 17:36 »
it can happen mate hence why you get a 3 year warranty  :wink:
you should be fine though I'd make sure you have breakdown cover  :lipsrsealed: :grin: :grin:
Offline simonpolly
« Reply #7 on: 20 September 2009, 17:42 »
Or go and knock on a neighbours door with a modern Vw they are bound to have some,i brought a bottle for my touran,its still 90% full and i`ve had the touran for 4 years
Offline Aidy06
« Reply #8 on: 20 September 2009, 17:48 »
I'll have to buy some in the morning, just hope its not a leak. Last thing i need, i have break down cover  :wink: Do you need to dilute it or what? Ive never, ever changed coolant before  :laugh:
Offline simonpolly
« Reply #9 on: 20 September 2009, 17:53 »
Just pour it in neat,you won`t use that much anyway and the more it is diluted the less protection you get from the coolant freezing in a very cold winter.
