Author Topic: COOLANT LEVEL LOW  (Read 11254 times)
Re: COOLANT LEVEL LOW
« Reply #10 on: 20 September 2009, 18:50 »
Before chucking in loads of coolant make sure it is the right type!
VW change the specs from time to time and if you do need a warranty claim and they find the wrong type of coolant in there you know what they're going to say. That might seem an odd thing to say but I've been driving VWs for over 20 years and the colour of the antifreeze changes from time to time over the years. I think it's red stuff at the moment.
Also you should make sure you have the correct mixture of antifreeze to water. Read the instructions on the bottle as a really wrong mixture can also be damaging IIRC.
Don't forget you've got a years VW breakdown cover too.  :smiley:
Offline simonpolly
« Reply #11 on: 20 September 2009, 18:55 »
Its the g12
Golfgti build quality is average at best.
Offline Aidy06
« Reply #12 on: 20 September 2009, 18:59 »
I'll just ask in stealers what i need, its pink at the moment thats in ive just checked
Offline simonpolly
« Reply #13 on: 20 September 2009, 19:04 »
Its g12 i checked earlier
Offline Aidy06
« Reply #14 on: 20 September 2009, 19:09 »
Thanks pal, were does it tell you? On the tank or in the manual?
Offline simonpolly
« Reply #15 on: 20 September 2009, 19:13 »
On the tank,my mk6 golf gti and 2.0ltr fsi touran both use the same,i knew it was G something or other so i went and looked its G12.
Offline Aidy06
« Reply #16 on: 21 September 2009, 08:31 »
Light came on again this morning whilst on the M61, turned around and went straight to stealer. They just topped it up with water, said keep my eye on it and if it drops again book it in
Offline Teutonic_Tamer
« Reply #17 on: 23 September 2009, 18:34 »
Just pour it in neat,you won`t use that much anyway and the more it is diluted the less protection you get from the coolant freezing in a very cold winter.
Hmmmm . . . you really shouldnt do that.  If the coolant to water ratio ever exceeds 60:40, then you dramatically lower the cooling efficiency.  Ideally, you should pre-mix it with water in equal measures.
I feel like a homo
« Reply #18 on: 23 September 2009, 18:38 »
Its the g12
It may say 'G12' on the expansion bottle, but as Rhyso correctly stated, it is actually 'G12 plus plus' (or 'G12++')
I feel like a homo
Offline simonpolly
« Reply #19 on: 23 September 2009, 18:58 »
Its the g12
If you go to the service counter and ask for G12 antifreeze for a gti mk6 golf will they give the correct stuff ? or do you have to say "hello i`m a complete idiot and assume you are to,can i have some g12++ ,or is there a funny handshake i need to give to ?) :rolleyes:
