Author Topic: Sony Set-up  (Read 2193 times)
Offline kr1s77
Sony Set-up
« on: 17 September 2004, 12:20 »
jus got MK3 golf with the original sony tape head unit & 10 disc changer, tried to get it out to check for pre-outs ( So i can attach amps & keep original set )but couldn't. Sumeone said these head units are alarmed, is this true, if so how do i get around that?
Thanx
kr1s77
ASV 1.9 TDI 110
Offline Dizzie
  • Make friends with your fast
Re: Sony Set-up
« Reply #1 on: 17 September 2004, 13:38 »
remove the surround by taking out the screws behind the vents. then you can lift the lot out in 1 go. should be able to see what's going on then. makes it easier to get it back in too.
Mk4 Golf 150PD
Offline kr1s77
Re: Sony Set-up
« Reply #2 on: 18 September 2004, 08:05 »
cheers  ;D, i'll have a go at that later when i get up, jus got in from work, so i'm off to bed now. goodnight, good morning ( oh wot-ever, you know wot i mean)
ASV 1.9 TDI 110
Offline kr1s77
Re: Sony Set-up
« Reply #3 on: 18 September 2004, 16:53 »
Jus F-up, took the screws out of the front of the unit, now the radio alarm is going off. how do i stop it any ideas???
thanks
ASV 1.9 TDI 110
Offline kr1s77
Re: Sony Set-up
« Reply #4 on: 18 September 2004, 17:27 »
Couldnt get it out, so i disconnected the one of the batteries in the unit that powers the alarm
ASV 1.9 TDI 110
