Author Topic: mirror polishing  (Read 3108 times)
Offline andc1
mirror polishing
« on: 16 September 2009, 15:05 »
hi all, prob been covered but cant really find any descent linkes to what i need,
ok ive gone from this
to this
and i just need to find out what to get to finish them off by getting the mirror polish look?
ive used some autosol but doesnt really work!
cheers
Offline Organisys
  • Old and Slow...
Re: mirror polishing
« Reply #1 on: 16 September 2009, 16:11 »
Get a dremel or better still a variable (slow) speed electric drill and a flexable drive shaft and a polishing kit from frost online or from eBay. These include polishing mops and polishing compound. You will get a much better result than by hand, unless you want to be polishing untill christmas of course!
VW BUSH
« Reply #3 on: 16 September 2009, 19:46 »
Polish in a figure of 8 rotating using finer compounds then buff with Autosol take care to keep coarse grades away and keep area clean, nothing worse than getting a mirror finish then buffing up to find a bit of grit on the cloth :angry:
I would then de grease and use a lacquer to protect Surface, Cast Ali has a Skin when it is gone you will find it corrodes very easily :smiley:
Offline warnesey333
« Reply #4 on: 16 September 2009, 21:26 »
Sorry to hijack but what sort of lacquer should we be using?
VW BUSH
« Reply #5 on: 16 September 2009, 22:18 »
High gloss Clear lacquer.
Wurth do a good one :smiley:
Offline andc1
« Reply #6 on: 16 September 2009, 22:27 »
