Author Topic: coolant  (Read 6521 times)
Offline bertmort8
  • 2.0gt fsi
coolant
« on: 11 September 2009, 09:46 »
my coolant keeps getting low, i fill it up between the min and max and within like 4/5 days it drops below the min.
just to off the cap and its nearly overflowed bubbling, ive just topped it up with bit more coolant but dont want to keep doing this
anyone got any ideas
wants a gt tdi
Offline bacillus
Re: coolant
« Reply #1 on: 11 September 2009, 10:16 »
How old is your car as I've read that the radiators on the gtis have a tendency to rot with age...
Without traction power is nothing!
Offline bertmort8
  • 2.0gt fsi
Re: coolant
« Reply #2 on: 11 September 2009, 11:37 »
only a 54 plate
wants a gt tdi
Offline Steve30
  • Ed30 .
Re: coolant
« Reply #3 on: 11 September 2009, 12:00 »
Yes , I have just noticed on my Edition30 that its low, only done 8,000 miles 58 plate? Whats going on here then? Do I need to get coolent for it or top up with water? Thanks Steve  :undecided:
Tiguan quicker than the Golf
Offline jaydubveedub
Re: coolant
« Reply #4 on: 11 September 2009, 12:17 »
Did it used to hold a consistent level or has it always been like this?
Certainly don't sound right to me, it must be leaking from somewhere. Does it leave coolant on the drive?
Do some basic checks on the hoses and rad, you should be able to see where it is coming out. Try doing this when it is both hot and cold, sometimes the system will only leak at a certain temp. due to things expanding etc.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline Hurdy
Re: coolant
« Reply #5 on: 11 September 2009, 12:22 »
I'd get the pipework checked first...can you spot a leak when you set off after the car has been stood?
Radiator could also be penetrated and leaking
How often do you check your oil? - is the oil filler cap creamy around the rim/dipstick encrusted? (possible leak through gasket)
max to min in 4-5 days is terrible. Mine doesn't use a drop between services although I still check it monthly.
Seat Leon Cupra Black 290 DSG
Offline Rhyso
Re: coolant
« Reply #6 on: 11 September 2009, 12:27 »
didn't AlanD have coolant loss issues and have some kind of seal replaced?  :huh:
EDIT - found it!
AlanD's Leaking Flange
Offline Steve30
  • Ed30 .
Re: coolant
« Reply #7 on: 11 September 2009, 12:30 »
Hurdy , there no leaks on my car at all mate? But its at the min level right now 58plate 8,000 on clock? Not another bloddy visit to dealers???? :undecided:
Offline bertmort8
  • 2.0gt fsi
Re: coolant
« Reply #8 on: 11 September 2009, 14:18 »
we have had the car about 9 months, only been doing this for like the last month or so, but using far too much
really havent got the money at this point to take it to a garage incase it costs too much
i never see any signs of leaking on the drive whatsoever. just had to go to halfrauds to buy more coolant as do not wanna top up with water
someone told me it maybe the radiator. will have to ring my warranty up and hope that they will cover the cost if any (just this minute realised i got warranty still)
wants a gt tdi
Offline Steve30
  • Ed30 .
Re: coolant
« Reply #9 on: 11 September 2009, 14:38 »
Can you use water to to top it up with? Mine is low as well?  :undecided:
