Golf mk2
DIY Resistor fix for Heater/Blow/Fan
Topic: DIY Resistor fix for Heater/Blow/Fan (Read 2215 times)
maxp
J reg 8v digi gti
09 September 2009, 13:38 »
I know the fan/blower only working on speed #3 is a common fault.
Seeing as a replacement resistor costs over 20 quid, ive heard its possible to just solder a new part onto the resistor.
Has anyone tried this? If so what is the part?
Ben Lessani
The poor mans MK2 Haynes author
Re: DIY Resistor fix for Heater/Blow/Fan
09 September 2009, 13:39 »
IIRC The resistor(s) are seriously expensive anyway.
The Mighty Elvi
I'm better than you today.
09 September 2009, 13:56 »
Take the blown one down to Maplin to match up the OHM rating, then just solder in it yourself.
http://www.csgnetwork.com/resistcolcalc.html
http://www.kpsec.freeuk.com/components/resist.htm
http://www.maplin.co.uk/Search.aspx?criteria=resistor&menu=-2
Piece of cake.
VeeDubGTI16v
Guest
09 September 2009, 14:36 »
if its the same as the corrado one its a thermal resistor you want
danny_p
Forum addict
09 September 2009, 14:40 »
Phuck the ohm rateing. Power disaption rateing is FAR more inporteant in this kind of appliction.
the resistor you replace it with needs to be able to dispapte adiquate power so it dosent melt.
getting the value of the reistor is going to be optimal but a littel pissy one will just burn
all the VW's have gone bar 1.
maxp
J reg 8v digi gti
09 September 2009, 14:45 »
Found this link, thought i'd share.
http://forums.vwvortex.com/zerothread?id=2665283
They seem to discuss replacing the thermal fuse rather than a thermal resistor though.
Last Edit: 09 September 2009, 14:54 by maxp
VeeDubGTI16v
Guest
Reply #6 on:
09 September 2009, 15:12 »
sorry i meant fuse!
Golf mk2
