Hey guys well I've got my mk2 abf on digi up and running, have been generally sorting lil bits and bobs out with it. It's developed a slight problem. Somtimes when i go to pull off, when i initially press the throttle(so its litterally just beginning to open), it'll just lose everything and nearly stall, but on continueing to press down the throttle it then picks up again and revs fine. It somtimes does this on slowing down to turn off on a junction, it'll nearly die. Any ideas? I've changed the fuel pump today and it's still a bit like it. When the coil blew we took off all the ignition system to check it and somebody noted that the dizzy cap was worn, could this be the cause of my problem? It's annying when trying to pull out of a junction or reversing, because i'm having to rev it high to keep going.
Cheers, Paul
