Author Topic: Abf cutting out  (Read 2746 times)
Offline hasekna
Re: Abf cutting out
« Reply #10 on: 09 September 2009, 19:03 »
Have been riding about in it a bit more today. It still does it. It seems to run fin on start up, but once it's warmed up so to speak it occasionally idle's lumpy and drops away when i first press the throttle? Have had a good look round all the inlet pipes and everything seems ok.
Offline danny_p
Re: Abf cutting out
« Reply #11 on: 09 September 2009, 21:34 »
IAT ??
all the VW's have gone bar 1.
Offline hasekna
Re: Abf cutting out
« Reply #12 on: 11 September 2009, 17:46 »
IAT ??
What's that mate?
After driving it a lot more now, i've realised the following.... 30 odd miles to a tenner isn't right! I think it's running massivly rich. When I bought the mk3 the bloke said that it failed mot on emmisions, this is proberly why lol! He said that the lambda sensor needed replacing, could a duff sensor cause this sort of problem. Could the ecu go into some sort of safe mode whereby it chucks in loads of petty to er on the safe side? Also, if you guys do think this is the case, would you advise trying one out of a scrappy ect?
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: Abf cutting out
« Reply #13 on: 11 September 2009, 17:48 »
what are the plugs like?
Re: Abf cutting out
« Reply #14 on: 15 September 2009, 11:20 »
if you disconnect the sensor it'll go into a safew map, it wont be ideal but it certainly shoulnt use that much fuel.  i think you might have to break out the multimeter and do continuity testing on the ecu pins
http://vwtech.no-ip.info/downloads/g3abfecu.pdf
Offline hasekna
Re: Abf cutting out
« Reply #15 on: 15 September 2009, 18:55 »
I've disconected the lambda and it seems to run a bit better, dosn't stall out at all now. still tries to die now and again, but generally its ok, I don't think it's running quite as much petty now either. When i bought the mk3 the bloke said it had failed the mot on emmisions, and that the garage had said it needs a new lambda. Which ecu pins should i do, all of them?
Offline Diamond Hell
  • Opinions я Us
Re: Abf cutting out
« Reply #16 on: 15 September 2009, 21:25 »
Did you just hook up the lambda out of the donor?
If so you need to replace it by the sounds of it.  If the lambda has failed it'll run like a bag of spanners until you disconnect it.
Offline danny_p
Re: Abf cutting out
« Reply #17 on: 15 September 2009, 21:54 »
new lambda needed then.   they get pissy with duff ones.    then leave the battery disconnected for 1/2 hour  then reconnect and turn ignition but dont start it ,  open throttel fully - hold it there then release and turn the ignition off.  then  start it
