If your mechanical skills are as good as your language skills, then I think you should improve both before trying anything nearly as advanced as seeking information about nailing a turbo conversion together out of some random bits you have lying around, or can buy 'cheap'.
Doing anything like what you're suggesting needs a lot of research. People will respond a lot better to your questions if you use proper sentences using real words and punctuation.
The flip side is I probably have a load of bits you can have for 'cheap' which may be useful in this conversion you're thinking about......
