Author Topic: hazards not working  (Read 898 times)
Offline daniel-1986
hazards not working
« on: 04 September 2009, 10:15 »
my hazards arnt working but indicators are working, wen the dashlights are on and i press the hazaed switch the indicators dont come on and the light inside the switch dims. when i put indicators on to go left or right and i put the hazard switch on it works
Re: hazards not working
« Reply #1 on: 04 September 2009, 11:06 »
does the light inside the hazard switch come on with the dash lights? if not check the earth to the switch.  also while you're there, check pin 30 is live, this is fed from fuse #4, so check that too :)
if all that looks ok id say its the switch thats duff
Offline daniel-1986
« Reply #2 on: 04 September 2009, 20:21 »
the light inside the switch comes on with the dash lights but the light in the switch goes out when u press the switch, to get the hazards to work u have to put the indicators on then press the hazard switch. the fuse is fine aswell
Offline jezza16v
« Reply #3 on: 05 September 2009, 12:56 »
Have a read through this lot, it might help.
http://www.golfgtiforum.co.uk/index.php?topic=116452.0
Offline daniel-1986
« Reply #4 on: 05 September 2009, 13:44 »
i read through that and followed by checking the pins, i get 12v thru pin 30, and only 4.5v thru pin 15 with the ign on and nothing through the pins, also when i press the hazard switch on and put the indicator on at the same time for them to work the indicator light on the clocks dont flash but the hazard switch light does
« Reply #5 on: 07 September 2009, 09:58 »
follow the wires back and you should find a huge multi connector near the fusebox, have a fiddle with this :)
Offline daniel-1986
« Reply #6 on: 07 September 2009, 14:45 »
wiggled that multiblock and now there working :smiley:
« Reply #7 on: 07 September 2009, 15:19 »
awesome :)
