Author Topic: help : what do these codes mean  (Read 1656 times)
Offline rhoddy
« on: 02 September 2009, 21:17 »
hi guys mk4 aum 20v turbo, driving home half an hour ago and the display says "STOP" and oil press,  car now sounds like a diesel , scared to start it again. oil was topped at weekend.
can anyone throw any light on this cheers  :cry: :cry: :cry: :cry: :cry:
16712 = knock sensor 1 circ high input
16717= knock sensor 2 circ high input
17705= connection turbocharger throttle valve pressure hose
17964= charge pressure contr negative deviation
16396= bank 1 : cam shaft A (intake) : advance setpoint not reached (over retarded)
Offline johnson6672
Re: help : what do these codes mean
« Reply #1 on: 02 September 2009, 21:23 »
http://wiki.ross-tech.com/index.php?title=Category:Fault_Codes&from=17114%2FP0730%2F001840
Have a look here may shed some light on it, some faults could be old/thrown up by other faults.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline rhoddy
« Reply #2 on: 02 September 2009, 21:42 »
cheers mate will get a look at this,
ther wasnt any codes as the car had the collant temp sensor  replaced 10 days ago as this was the fault code that came up  :undecided:
Offline alexmatt
« Reply #3 on: 02 September 2009, 22:10 »
ive come across a couple of those faults before and checked the throttle body.i had to clean it up and readapt it and all was fine.
these were the two i had on a 1.8t auq engine
mk2 g60 edition one
Offline rhoddy
« Reply #4 on: 02 September 2009, 22:52 »
just had a look at the car and pool of oil underneath  :cry: , taken the plastic cover off top of engine and the other cover underneath that to have a look and theres an oil pipe split  and when i touched it  , it sheared off at the join which maybe explains why the car now sounds like a diesel ie cams hav no oil  :huh:, the car was only driven about 1.5 miles like this when the STOP light started flashing, hope theres no damage done.  :sick:
Offline sambo
« Reply #5 on: 02 September 2009, 23:02 »
Bummer !  :sad:
At least you weren't travelling down the motorway at the time though :afro:
Sam
Sam
AXX power!  ..   Tinkering has started.... :smiley:
Offline GOLF_STU
  • THE_GIT
« Reply #6 on: 02 September 2009, 23:10 »
oil pipe or the gas recirc pipes of the rocker cover?
V TEC KICKED IN Y'ALL!!!
Offline rhoddy
« Reply #7 on: 02 September 2009, 23:17 »
not sure mate, the pipe thats sheared off sits directly under the perforated plastic cover and oil is coming out of it dripping ont ground,
what is the gas recirc pipe ?
oh and car only boosts to 0.5 psi
Offline richw911
« Reply #8 on: 02 September 2009, 23:18 »
Should be ok get the pipe fixed and top it up. Fingers crossed for you  :smiley:
