Guys,
At the moment i own a Mrk 4 VW Golf GTi-Turbo 20v and recently i got done was put on rims and jom coilovers front and rear, i think its been dropped around 40mm.
Anyways on the way home tonight from work everytime i press the brake pedal the front right wheel or brakes is vibrating.
I normally stop on the way home nearer to home for a smoke at this small quite church, so i did today to investigate, i did full lock to the right and looked underneath at the front right wheel. I couldnt see anything broken, everything looked ok and where it should be, this vibration only happened recently.
Does anyone know what it could be ?
Also after the bank holiday im getting a remap, pipecross panel filter and DV put in by R-Tech, should i invest in some good arbs, maybe the drop is causing this (when i turn left my front right driveshaft is rubbing on the arb, making a noise)
What should i do and what could be my problem with the brakes.
Thanks all.
