Author Topic: Really need your help, front brakes  (Read 2520 times)
Offline johnson6672
Re: Really need your help, front brakes
« Reply #10 on: 28 August 2009, 20:35 »
Not lowered yet, the car was mapped when i got it but its great, power is good and my other car is a scooby!
I would get it checked asap just incase something has come loose/undone from your previous work.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline rheady
« Reply #11 on: 29 August 2009, 13:56 »
Before you do anything else I'd sort out that problem.If you did'nt have it before you changed the suspension I'd check all the suspension again. Have you put the wheels on tight enough. Have you got anything sticking in your tyre, you'd be supprised what vibration you will get.
      As for the brakes if they are that bad you'd feel the wobble all the time at all speeds.
Offline hobbiniho
« Reply #12 on: 29 August 2009, 15:28 »
Anyways on the way home tonight from work everytime i press the brake pedal the front right wheel or brakes is vibrating.
Does anyone know what it could be ?
if the vibration is only happening when you are using the brakes then you have a warped disk, as for the arb get the whiteline one as it goes under the drive shaft apposed to over it as the standard one does damian@dpm does a good price on these see here http://www.dpmperformance.co.uk/whiteline-22mm-front-anti-roll-bar-golf-4-14-16-18-18t-19sdi-19tdi-20-23-v5-0797-p-2815.html
Offline rakesh27
« Reply #13 on: 30 August 2009, 00:03 »
Guys.
Thanks for your help, i took the car back to my mechanic he checked the front disc and said as you suspected they are warped, i got the front discs and pad changed now all is good.
About the whiteline arbs, wouldnt i need the adjustable ones instead of the one you put inthe link, are these the correct ones i need to stop rubbing and for me to lower alittle more on front and rear.
http://www.dpmperformance.co.uk/whiteline-22mm-front-adjustable-anti-roll-bar-golf-4-14-16-18-18t-19sdi-19tdi-20-23-v5-0797-p-2816.html
Thanks again all.
Ps cant wait to get back to work, im getting my remap on tuesday, whoooooooooooooohoooooooooooo
