Author Topic: Reverse Light  (Read 2022 times)
Offline tariqb
Reverse Light
« on: 26 August 2009, 17:40 »
The reverse light isn't working  - have changed the bulb and still no joy  -Any ideas??
Offline J5H VW
Re: Reverse Light
« Reply #1 on: 26 August 2009, 17:42 »
Reverse light switch on gearbox.
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline tariqb
Re: Reverse Light
« Reply #2 on: 26 August 2009, 17:43 »
how easy/difficult is it to change? Can i do it myself?
Offline J5H VW
Re: Reverse Light
« Reply #3 on: 26 August 2009, 17:54 »
If you are a practical hands on person, not put off by DIY, then I dont see why not.
I am sure a google search shoudl throw up some instructions etc.
gtigolfthree
Re: Reverse Light
« Reply #4 on: 26 August 2009, 18:09 »
Check your fuses first.
Offline J5H VW
Re: Reverse Light
« Reply #5 on: 26 August 2009, 18:12 »
Didnt realise there was a sep fuse for the reverse lights. doh!
I had a similar issue on mine, turns out the bulbs and switch was fine, and ended up needed an auto-electrician to trace the fault in the wiring somewhere.
Offline richw911
Re: Reverse Light
« Reply #6 on: 26 August 2009, 18:31 »
Have a look as the wires on the gearbox is a VERY common fault  :wink:
http://www.golfgtiforum.co.uk/index.php?topic=87373.0
Offline chrisj
Re: Reverse Light
« Reply #7 on: 26 August 2009, 21:34 »
my reverse lights flicker now and again so would this be the same problem??
R Tech stage 1 AUM, Pipercross panel filter, forge 007p, Santa Monica's,Lowered 35mm Jamex Shocks and springs, Milltek Exhaust, mk5 rear wiper
Offline richw911
Re: Reverse Light
« Reply #8 on: 26 August 2009, 23:24 »
Id would say so defo worth a look  :wink:
Re: Reverse Light
« Reply #9 on: 27 August 2009, 00:21 »
If you remove the plug from the switch and bridge the wires it will confirm if the switch has failed.
