Author Topic: wheel arch sub box advice  (Read 5932 times)
jamie16v
Re: wheel arch sub box advice
« Reply #10 on: 29 August 2009, 18:26 »
  :undecided: eerm, i bought a vibe slick s12 instead..  :undecided:
looks nicer anyway..lol any ideas what size box it should have?. i think i have 200 worms to play with..
just gotta get this arch box finished now.. god, it takes some matting and resin dont it?...
jamie16v
« Reply #11 on: 29 August 2009, 18:30 »
oh yeah, and how many layers of this FG matting should i use? does it have any acoustic properties or is it just the MDF baffle at the front that does all that work?.
i know it shouldnt have any air leaks which i am confident about. ive done loads of this FG stuff before, just not in audio.
Offline Len
« Reply #12 on: 01 September 2009, 12:38 »
If its just glassfibre other than the front panel I would use 3 layers.
Plus think about lining it with dynamat.
www.sas.org.uk
www.the-ace.org.uk
jamie16v
« Reply #13 on: 01 September 2009, 14:43 »
christ this is becoming expensive.... :rolleyes:
Offline Len
« Reply #14 on: 01 September 2009, 15:01 »
No such thing as a free meal!  :wink:
Where you getting your gear from jamie? I used a couple of those Halfords large repair kits.
www.sas.org.uk
www.the-ace.org.uk
Offline B-chi
« Reply #15 on: 01 September 2009, 19:22 »
cfsnet.co.uk should see you right.
You can pick which thickness of matting you want. Ideally I would say 600g.
Sound deaden the wheel well, but I wouldn't worry about sound deadening the enclosure. Better off putting an extra layer of fiberglass on it. You don't want any flex at all in the box so if it looks a bit flimsy do another layer.
jamie16v
« Reply #16 on: 01 September 2009, 20:58 »
i used a local motor factors which has proven to be quite wallet damaging. they sell the same kits as halfords. i used two of those kits and bought and extra square of matting metre instead of buying another kit. the box now seems quite rigid, i have also lined it with paper mache (with PVA not wallpaper paste).
all i have to do now is fit the baffle, i got some chip board lying about which i could use or should i spend that extra cash and use MDF?.
also wheres the best place to get box carpet?.. want it to match the boot the best i can..
Offline Len
« Reply #17 on: 01 September 2009, 21:05 »
MDF is a bit denser than chipboard. Shame you aint closer as have a few pieces of MDF lying around!
I used PVA/papier mache to get the shape of mine. Ended up ripping all of it off in the end!
How are you fixing the enclosure to the car? I used the 3 self tapping holes.
www.sas.org.uk
www.the-ace.org.uk
jamie16v
« Reply #18 on: 01 September 2009, 21:17 »
im gonna use velcro or simular.. :laugh:
i dont want to have to unscrew it everytime i take it out.
its a good fit so shouldmt fly about too much... fingers crossed anyway.. :drool:
Offline Len
« Reply #19 on: 02 September 2009, 09:13 »
Never taken mine out!
www.sas.org.uk
www.the-ace.org.uk
