Author Topic: stealers  (Read 1564 times)
Offline LAD
stealers
« on: 24 August 2009, 18:34 »
Not sure if any of you have experienced this but I had a service @ 22k miles and since then every month without fail the service light has been coming back on.  Each time it has been taken back to the dealer and reset, today was the third time I have taken it back and this time they reset the whole systyem (current milegae 28k, next service due @ 33k), apparently if it comes back on again I need a new dash panel which will knock me back £359!  Any thoughts on this??  :angry:
Offline No Golf Clubs at all
Re: stealers
« Reply #1 on: 24 August 2009, 18:38 »
Are you in warranty, only ask as you have quite low mileage.
Let the fun begin........Red Gti, full colour coding, DSG, Xenons, Winter pack, Lux pack, Highline, Sat Nav, Sunroof, Leather, Milltek, ABT rear valance, Goodyear F1 Asymmetrics....pescaras :-)
Offline LAD
Re: stealers
« Reply #2 on: 24 August 2009, 18:44 »
No out of warranty! The car was an import bought by the first owner, i'm the third.
Offline Teutonic_Tamer
Re: stealers
« Reply #3 on: 24 August 2009, 19:06 »
There was a known and documented issue regarding early Mk5s - whereby the service reminder would go t!ts up.  But I can't remember if it was just a flash update, or a complete new dash pod.  Sorry I can't be more specific.
I feel like a homo
Re: stealers
« Reply #4 on: 24 August 2009, 20:14 »
If it's a known and documented issue vw just might pick up the parts bill, leaving you with the labour.... Long shot but worth a try ... Ya just never know.
Offline jaydubveedub
Re: stealers
« Reply #5 on: 24 August 2009, 20:15 »
Can you make the service reminder go out if you reset it manually or can it only be solved by the dealer?
For the sake of £360 (assuming that is the only issue) I would be happy to reset it manually each time, as it only takes a few seconds. (check the forum for instructions on this).
As TT says, might be worth going down the route of speaking to VW warranty/technical to see if there was a software update.
As it would happen, I just had a new dash pod fitted (thankfully under warranty). Different issue though, the highline display had pixel loss.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline LAD
Re: stealers
« Reply #6 on: 24 August 2009, 20:24 »
it can be reset manually but over the last 3 months it kept coming back on, i'm hoping this time it will stay off as they have reset the whole system.  they checked for updates today but nothing needed doing, so i will have to wait and see if it comes on again next month!
Offline FamilyDub
Re: stealers
« Reply #7 on: 25 August 2009, 09:10 »
See this thread in the MKV Maintenence & Info Section -->
http://www.golfgtiforum.co.uk/index.php?topic=39952.0
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
