Author Topic: damn...just sprung a leak..(help needed)  (Read 1641 times)
Offline yorkshire_gti
« on: 24 August 2009, 16:13 »
I was just driving home and the temperature light started flashing but my
temperature gauge is still on halfway..?
Its a 1996 mk3 cabrio with a 1.8 AAM engine...
i have sprung a small leak from the middle of the metal water pipe on the right hand
side of the engine(the pipe that bends around the front of the block)  :angry:
what is the exact name for these and are they easy to replace?
is the metal bit called a water pipe?
are they costly?
thanks..
« Last Edit: 24 August 2009, 17:45 by yorkshire_gti »
Offline axewielder
  • 95 dragon 8v
Re: damn...just sprung a leak..(help needed)
« Reply #1 on: 24 August 2009, 17:17 »
yeah these ten to rust through, just waiting for mine to go, http://www.vagcat.com/epc/cat/vw/GOSY/1995/143/49/1489292/ I think you want no8 if its the right engine, just says 1.8, dont know about price, try dealers, gsf, euro vwspares ect.for prices, shouldnt be the most dificult thing to replace, can get you exact part no if you want when i get home later?
« Last Edit: 24 August 2009, 17:18 by axewielder »
« Reply #2 on: 24 August 2009, 17:26 »
hi...
yes it looks like the number 8 to me...
part number would be great...
seen this on gsf...will this be it do you think?
17876  METAL WATER PIPE   G3 1.8 AAM/ABS/ADZ Engs. 9/92>97 (Ch.P160001>)     23.50
« Last Edit: 24 August 2009, 18:55 by yorkshire_gti »
« Reply #3 on: 25 August 2009, 13:29 »
I got the pipe off which was not too difficult...
just waiting for the new one from gsf...
Just need to work out now why my fan does not seem to be working  :rolleyes:
« Reply #4 on: 26 August 2009, 12:43 »
got the new metal water pipe today and fitted it..filled it up but the fan still does
not seem to be working...
ive also flushed it out with the hose pipe
the engine seems very hot but the temp gauge never goes above halfway?
the top and bottom hoses on the radiator are both very hot so will it defo be the
switch on the radiator that needs replacing before i go and buy one..?
If i bridge the points the fan does spin!!
is there anything else that may need replacing?
 :undecided:
« Last Edit: 26 August 2009, 12:49 by yorkshire_gti »
Offline axewielder
  • 95 dragon 8v
« Reply #5 on: 26 August 2009, 13:59 »
check for airlocks too, shouldnt need anything else :smiley:
« Reply #6 on: 26 August 2009, 14:42 »
ive got it running hot with the lid off and squeezed all the pipes..
gtigolfthree
« Reply #7 on: 26 August 2009, 14:53 »
My fan doesnt come on till the gauge is just past half way and that only happens in traffic on hot days.
Offline MK3TDi1996
« Reply #8 on: 26 August 2009, 15:11 »
if you're still having trouble with your fan, chances are it'll be the fan switch! cheap cheap and damn easy :)
« Reply #9 on: 26 August 2009, 16:01 »
thanks all...
gonna get the fan switch as soon as i get paid in a few days...
