Author Topic: Debadging  (Read 1046 times)
Offline earlbob
Debadging
« on: 21 August 2009, 14:57 »
Are the Golf and SE badge on my golf just glued on or does it require some bodywork if i want a debadge?
Im not taking it off to leave holes thats all lol.
Thanks
Ryan
adamrob69
Re: Debadging
« Reply #1 on: 21 August 2009, 15:18 »
mine were stuck on.
i just pulled mine off the and with alot of scrubbing removed the leftover sticky bits!
Offline Reasty
  • Alpine white valver.
Re: Debadging
« Reply #2 on: 21 August 2009, 15:32 »
Yep just stuck on (was on my gti anyway) but as said will leave the backing on the car,so ull need to get some white spirit or something similar to get the sticky stuff off,then give it a coat of polish and ull never know they where on there. :smiley:
Re: Debadging
« Reply #3 on: 21 August 2009, 15:47 »
Use a bit of fishing line and work it behind the badge, then use meths to clean up as required.
Offline DrewGTI
Re: Debadging
« Reply #4 on: 21 August 2009, 16:42 »
i used t-cut to clean up where the badge had been. . works a treat!  :smiley:
Offline VR6-Joe
Re: Debadging
« Reply #5 on: 21 August 2009, 22:00 »
hammer and chisel i'm afraid
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Adam
Re: Debadging
« Reply #6 on: 21 August 2009, 22:15 »
Grinder if all else fails
Down Hill From Here.
Offline Mr.Tom
Re: Debadging
« Reply #7 on: 21 August 2009, 22:28 »
With my old Escort, it was a case of warming it up with a heat gun to losen the glue. Then get behind it with an old credit card (or loyalty card/gift card etc.) The plastic card will help protect against scratches. When you have got all the glue you can off, a good going over with t-cut or similar will get rid of the last bits. Can take a while tho, but you will have the cleanest patch on your car ;) (well, I did. I had to do the whole boot to match :D )
