Author Topic: ecu changed but still problems!  (Read 3328 times)
adamrob69
Re: ecu changed but still problems!
« Reply #20 on: 19 August 2009, 09:24 »
by plug and play i meant that it would fit on the car without having to alter anything. But it would still need programing so the imboliser worked. (so not true plug and play perhaps)
all you need to do is program it. 1 hour rate at main dealers for about £60 i think mine was (which also included fitting)
a £20 lead of ebay wont do it, as they are not licensed properly from experiance, and you would need to know wat you was doing if you wanted to attempt it yourself.
Offline tshirt2k
  • Been there...Done that...
« Reply #21 on: 19 August 2009, 10:32 »
You can code keys with vag com, but prob need full version and you need an skc/pin. Which can be retrieved using vag tacho, but if you plug in with that you might aswell code the key with it.
Mk3 ABF 16VT Megasquirt V3
Offline AudiA8Quattro
« Reply #22 on: 19 August 2009, 10:58 »
The leads from ebay will work, but you will need know how to register it.
Or you could buy vag-com 704 from www.chinavasion.com for £30, thats fully registered but don't update it!!
I think you will probably need the pin code, however i don't remember needing it on the Audi???
adamrob69
« Reply #23 on: 19 August 2009, 12:08 »
What i was led to believe is that the lead acts like a licensing dongle with the fully registerd software, which the cheepo leads dont have? but they will let you scan for faults
« Reply #24 on: 19 August 2009, 13:23 »
Only the newer versions need a lead with a dongle.
Earlier versions like 311 and 409 need to be activated differently.
311 with a code, 409 with a file.
You can buy generic leads that have a dongle but you can't update the software.
check http://www.chinavasion.com/product_info.php/pName/vagcom-v7041-usb-to-obdii-cable-for-car-diagnostics/
