Author Topic: ecu changed but still problems!  (Read 3326 times)
Offline AudiA8Quattro
Re: ecu changed but still problems!
« Reply #10 on: 18 August 2009, 21:23 »
As far as i know all you have to do is re-program all the keys to the ECU, nothing else needs programming.
Is that correct Wayne?
Offline av_golf
« Reply #11 on: 18 August 2009, 21:53 »
yes its a valver. how much would the dealers charge to get it programmed? has anyone on here got vagcom?
Offline Mikester
  • Civic Type R
« Reply #12 on: 18 August 2009, 22:44 »
If not, C2 motorsport will de-imobilise the ECU for about £100. So i dont matter what key you used, or anything.
Offline boneybradley
  • Back in a Mk3...
« Reply #13 on: 18 August 2009, 23:19 »
It's vag-tacho thats is required to code key's etc..not vag-com!
and regarding the plug and play bit...as long as the ecu matches the o.e part number (see list below) then all that needs sorting is the immobiliser
16 Valve ABF
91-94 Bosch KE Motronic: 0 261 000 852/3::8A0907404 (non immobiliser)
92 on Siemens Digifant   : 5WP 4 066 :::::::::::037 906 024 G
        Bosch Digifant    :  5WP 4 133::::::::::::037 906 024 AB
95 on  Siemens Digifant  : 5WP 4 237/304 ::::::::::::037 906 024 AE/BE
« Reply #14 on: 18 August 2009, 23:22 »
16 Valve ABF
Who told you that??
You can code keys on VAG-com, i have  :smiley:
« Reply #15 on: 18 August 2009, 23:25 »
I believe that is correct as I looked at having it done when I changed the steering column but managed to swap the chip over.
  • Back in a Mk3...
« Reply #16 on: 18 August 2009, 23:25 »
Am I thinking of the later key's only? (I know my old mk3 one's were done by the local key cutter! and my passat wont/cant be coded on vag-com)
Offline av_golf
« Reply #17 on: 19 August 2009, 02:12 »
the old ecu has the exact same part number as the new one. is it just the immobiliser then? what vag-com do i need? theres ones on ebay for about £20, am i able to do it through one of them?
« Reply #18 on: 19 August 2009, 09:03 »
Not sure, should be able to do it with it to be honest.
« Reply #19 on: 19 August 2009, 09:08 »
Vag-com should be able to code all cars. I didn't think vag-tacho could do it, just mileage correction, but to be honest i've never used it.
What year is your passat? i can recode my Audi A8, and thats a 1998.
The older cars have a different procedure for programming than the newer ones.
