Author Topic: is engine flush a bad idea on high miles  (Read 2484 times)
Offline tg1
« on: 18 August 2009, 08:46 »
as above really, mines on just over 125k and is due a oil change and service soonish.
I've got some engine flush but as its on high miles i don't want to do it more harm than good
Offline richw911
Re: is engine flush a bad idea on high miles
« Reply #1 on: 18 August 2009, 19:01 »
Some people swear by it but i dont use it at all.
Get some of this IMO:
http://www.slick50.com/products/AdvFormulaEngineTrt.htm
Along with some quality oil :afro:
« Last Edit: 18 August 2009, 19:02 by richw911 »
Offline AliBailey88
« Reply #2 on: 18 August 2009, 19:39 »
i used some on my mrs old diesel zx, f**ked it rite up, bits of coke from what the flush had melted off the valve seating stuck 2 exhaust valves open.
never use again
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 18 August 2009, 20:11 »
just drop the oil while it's still warm.. most of the cack will fall out that way
Offline MK3TDi1996
« Reply #4 on: 18 August 2009, 20:21 »
Not saying others are wrong but - i've never had any trouble using it on any of ther cars i have serviced.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #5 on: 18 August 2009, 21:00 »
Flush will never ever grace any of my lumps.  :)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 18 August 2009, 21:09 »
..just make sure you put some cream on them if they develop a rash
« Reply #7 on: 18 August 2009, 21:24 »
:laugh:
Offline AudiA8Quattro
« Reply #8 on: 18 August 2009, 21:29 »
Nothing wrong with using engine oil flush at all, if it causes damage then the internals are probably on the way out anyway.
However only run the car at idle when its in the engine, do not drive the car.
I've read plenty of people on the internet that have done that, and you will risk f**king it  :rolleyes:
If you are worried about crud accumulating in the sump, drop it off and give it a good clean.
Offline tg1
« Reply #9 on: 18 August 2009, 22:13 »
would it be worth whipping the sump off and cleaning the gunk out? when i drop the oil out?
I guess i'd have to change the gasket but is the sump plug reusable?
Just blast it out with a pressure washer? or something a little more indepth.
