Author Topic: dumps valves??  (Read 7038 times)
Offline bobreece
dumps valves??
« on: 18 August 2009, 00:50 »
does anyone have one fitted to a turbo diesel as i rad on baileys site that there is no point and they dont support tdi's?
Offline Rhyso
Re: dumps valves??
« Reply #1 on: 18 August 2009, 08:38 »
correct
waste of time and money
Offline bobreece
Re: dumps valves??
« Reply #2 on: 18 August 2009, 10:36 »
even if its remapped?
Offline Rhyso
Re: dumps valves??
« Reply #3 on: 18 August 2009, 10:38 »
read very carefully as i'll type this only once more
dump valves on a TDI are a COMPLETE WASTE OF TIME
What would you spend?? £200 on an R-Tech remap to make your car go faster or £200 on a useless piece of crap which makes a stupid noise and has NO PERFORMANCE BENEFITS?  :huh:
 :wink:
Offline bobreece
Re: dumps valves??
« Reply #4 on: 18 August 2009, 12:46 »
i get what your saying its not 200 for valve its 40 and why no good on diesel and good on petrol then sorry to be stupid am new and still learning all this guys?
Offline Rhyso
Re: dumps valves??
« Reply #5 on: 18 August 2009, 13:22 »
its the way the system works.  Diesels are electronic and vaccum controlled
not sure on the ins and outs but please do not waste your money  :smiley:
Offline Rhyso
Re: dumps valves??
« Reply #6 on: 18 August 2009, 13:44 »
some info i found
A dump valve isn't used on a diesel because unlike a petrol engine there is no throttle butterfly. In a petrol engine when you shut the throttle the dump valve prevents excess pressure build up. The turbo diesel works by adjusting the pitch of the turbine blades.
Hope that clears things up  :smiley:
Offline Phil.O
Re: dumps valves??
« Reply #7 on: 18 August 2009, 14:05 »
do diesels not use a special kind of dv? a recirc valve or something?
does a similar job just without the noise or am i miles out?
a work in progress......someday i might think i'm happy with a car....maybe
so far: 40mm Gmax lowering kit, upper and lower S3 strut braces, pipercross panel filter, Smoothed air box and 18" Audi R8 reps
Offline Rhyso
Re: dumps valves??
« Reply #8 on: 18 August 2009, 14:08 »
read the above ^^^^^^^
Offline bobreece
Re: dumps valves??
« Reply #9 on: 18 August 2009, 16:50 »
so no point at all in replacing oem one as its up to the job no matter remapped or not? and no one on here with a deisel has one?
this is the last questions am asking guys thanks so far for replies
